Question about Konka Televison & Video
  • 4,234 Answers
Can you please update this with the make and model numbers? Without that info, I can not look up the parts.
Posted on Aug 07, 2008
C1288 code
ABS module
Brake pressure transduser Main primary Input circuit Failaure
could be
Bad abs pump
Bad ABS modual
no power at abs pump
no ground at abs pump
wiring problem
hope this helps
Jan 30, 2013 | 2005 Ford Freestar
i would check to see if the stand by supplies are on the power board and then check to see if the on supply comes up briefly when power is pressed it could be the power board or main board testing the supplies will narrow down which board you need.
Aug 23, 2012 | Sanyo Dp50741
No power to fuel pump
I have 1988 454 1-ton and 1990 454 1-ton both get the power supply thru the ignition modual. 99% positive that is where the problem is
Aug 01, 2012 | 1991 Chevrolet Silverado 2500
Green light comes on
Most Mitsubishi sets have a feature known as error code operational check. First up unplug the set and replug it. Press and hold the "Device" and "Menu" buttons for 5 seconds. You wil see a series of blinks a 1/2 second pause and another series of blinks. COunt the blinks before and after the pause and let me know. If its an issue other than power supply then you should get an error code. Power supply is the only thing that the operation check does not check.
Jul 06, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Behringer pmh mixer manual. 20 channel 800watt powered mixer no speaker output. I need to test the power supply and the amp modual. Thanks
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Nov 28, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
I need a service manual for a behringer pmh500 powered mixer
If LED's or other indicators are lighting, then the power supply is likely OK.
If nothing lights, then the supply has fried and LIKELY fried as a result of one of the power amps shorting.
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Poloroid 32 in HD LCD with DVD player
check for shorted diodes in the power supply. the power supply is located in the modual.
Feb 29, 2008 | Polaroid 4226TLMB 42 in. LCD TV
Televison & Video Logo
53 people viewed this question
Top Konka Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
