RX-303 NAKANICHI & TEAC-2000X REEL TO REEL
Have a Nakamichi RX-303 CASSETTE DECK and TEAC 2000x REEL TO REEL . Both Decks stopped playing after 3 yrs in storage. Both decks will rewinds and fast forwards the tape but when press the play button I hear a click but nothing happens. Any assistance in this matter will be greatly appreciated.
Also do you know any reliable repair facilities in Virginia or New-York who can repair them?
Thank you for your time
Roland
  • 1 more comment
  • shadayday Aug 08, 2008
    Do you mean the "CAPSTAN BELT"? If yes, any idea where I can get them? Thanks
  • Sam Palermo
    Sam Palermo Dec 21, 2017
    Hi Roland, The Teac can be repaired at New Jersey Factory Service. The Nak can be done at my shop as I have a Nak Technician who fixed them. I am in Chicago. The other choice would be Hi Tech service in Nashville. There is Mr. Hermann but he might cost too much plus has a long waiting list.
    Brigadier General:
  • 6,966 Answers
The click you did hear is the solenoid engaging. Both the Nakamichi and the Teach often uses a different motor for the play and for the rewind/forward functions.
The capstan belt you referred to is often a flat belt roughly 5mm in width but with the diameter varying from model to model. I would suspect that the belt has melted or broken in pieces. best way hopefully on parts replacement would be as per sample but with the previous statement might be impractical. You might be better off with winging the size with a string of some sort and just tie around from the motor around the flywheel/capstan.
As to a repair facilities, pls try entering your Zip Code on the small window "Repair Service", I believe on the right of this page.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 08, 2008
  • Louie  Role
    Louie Role Aug 08, 2008
    Hi again,
    If you are considering a DIY (do-it-yourself), Abrsvcs's post bears merit other than just the belt(s). Should you be interested, common replacement parts for the Nakamichin maybe found here as a start. Am not so sure of the Teach, you may want to try here.
  • 4,234 Answers
These decks need a complete overhaul. There are belts and "idlers" inside that are made from rubber that have dried out and slip. The Rx-303 needs a tire replacement. This tire only comes into play when in play mode. The FF and REW functions are powered only by a belt. Changing hte idler tire is a bit tricky in these units if you have not replaced one before. Given the value of these units, I'd recommend that you have a servicer in your area overhaul these. The parts expense should not exceed $15 for either deck. Check in the area for the labor costs. Both units are definately worth the repair cost.
Dan
    Genius:
  • 1,847 Answers
Seem problem with the gear belt.
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
FF problem on Teac Reel to Reel
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old.
I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
Jul 15, 2013 | Teac Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Older Teac cassette decks
I had an Aiwa dual deck and by the way your describing it, when you select Cont. Play press play on one deck then play on the other. I am not sure if there's a difference as to which you start with. When the first deck is done playing both sides, the unit will goto the second deck and play both sides, then back to deck 1.
Jul 01, 2008 | Audio Players & Recorders
Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Apr 06, 2008 | Audio Players & Recorders
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
209 people viewed this question
 Grubhead
Grubhead
