Connecting a turn table to a micro stereo system
Hi
I have just bought a philips MC M204 micro stereo system it has a 3.5mm line in socket. I am looking to buy a cheap turntable that I could connect to it for example the Bush MTT1, would this work or do you have any other suggestions?
  • paulie99 Aug 08, 2008
    Thanks very much for your help
  • 515 Answers
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Posted on Aug 08, 2008
SOURCE:
Is there some way to connect an ipod to a Philips mc-m570 stereo?
the interface will probably only work with the phillips software, but many of those stereos support playing from a flash drive.
Oct 20, 2011 | Philips MCM570 CD Shelf System
My gigabyte motherboard will support single chip 2gb ram and i have to upgrade my ram into ddr2 533mhz to ddr2 667mhz or 800mhz it is possible for my motherboard
Gigabyte GA-945GZM-S2 - motherboard - micro ATX - LGA775 Socket - i945GZ specifications
  • it looke like the supported RAM
  • Supported RAM Technology DDR2 SDRAM
  • Supported RAM Speed 533 MHz , 400 MHz
  • hope this helps
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory None
  • Chipset Type Intel 945GZ Express / Intel ICH7
  • Max Bus Speed 800.0 MHz
  • Processor Socket LGA775 Socket
  • Max Processors Qty 1.0
  • Compatible Processors Core 2 Extreme , Celeron D , Core 2 Duo , Pentium D , Pentium 4
  • Memory
  • Max Supported Memory 2.0 GB
  • RAM Features Dual channel memory architecture
  • Graphics
  • Graphics Controller Intel GMA 950
  • Memory Allocation Technology Dynamic Video Memory Technology 3.0
  • Audio
  • Type High Definition Audio (8-channel)
  • Audio Codec Realtek ALC888
  • Compliant Standards High Definition Audio
  • LAN
  • Network Controller Marvell Yukon 88E8001
  • Network Interfaces Gigabit Ethernet
  • Modem None
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x Processor ( 1.8 V ) - LGA775 Socket ( x4 mode ) , 4.0 x PCI Express x16 - DIMM 240-pin , 3.0 x Memory , 1.0 x PCI
  • Storage Interfaces Intel ICH7 : ATA-100 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s) , Intel ICH7 : Serial ATA-300 - connector(s): 1 x 40pin IDC - 2.0 device(s)
  • Interfaces 1.0 x Audio - Floppy interface - Mini-phone stereo 3.5 mm , 1.0 x Storage - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Audio - RS-232 - 25 pin D-Sub (DB-25) , 4.0 x Serial - VGA - Mini-phone 3.5 mm , 1.0 x Microphone - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style) , 1.0 x Display / video - IEEE 1284 (EPP/ECP) - 4 pin USB Type A , 1.0 x Audio - Line-out (center/subwoofer) - Mini-phone 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - Line-out (side surround) - RJ-45 , 1.0 x Audio - Line-in - Mini-phone stereo 3.5 mm , 1.0 x Hi-Speed USB - Line-out (rear) - 9 pin D-Sub (DB-9) , 1.0 x Audio - Input - Mini-phone stereo 3.5 mm , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 1.0 x Audio - 4 pin MPC
Apr 09, 2011 | Gigabyte GA-945GZM-S2 Motherboard
Connecting laptop computer to rx-v395 yamaha amplfier
Hi, yes it is possibe, but you are going to have to buy a stereo 2.5mm jack to 2 phono lead. Connect to headphone socket on laptop and the other to a line input on amplifier and adjust setting to suit.
I hope this helps, if you need more info, I will help.
Regards - Anthony
Feb 06, 2010 | Marantz MA-9S1 2-Channel Amplifier
Connecting creative labs fps 1600 sound system to laptop. How?
hi, i recommend just using the headphone out, and it probably will not hurt the notebook, as it is not feeding back into the notebooks sound device. you may wish to do as i did, and get a creative labs external sound card. much improvement over the on-board high def sound built into my acer notebook.with all the connections you would want! as for speakers there are alot of models to pick from.i usually go with creative, but this time i went logitech- thx,dts,ect. and i am very happy. i hope this helps you make a decision on what do. good luck!glen
Feb 15, 2009 | Creative Labs FourPointSurround FPS1600...
Is it my battery or bad system?
I had the same problem a few years ago. Creative said that it was due to connecting the player to a lead that was plugged in to a socket which was already turned on. They recommended pluging in the player, then turning on the socket. They also had downloadable firmware to fix this problem.
Good luck.
John Parr
Jan 06, 2008 | Creative Labs Zen Micro MP3 Player
Power Supply transformer failed
2 x 5 Watts RMS Stereo
5 watts continuous RMS power output per channel, at 8
ohms, from 120Hz to 15kHz, with no more than 10%
Total Harmonic Distortion (THD).
Jun 04, 2007 | Philips MC-105 CD Shelf System
953 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
