Question about Samsung S1030 Digital Camera
Battery life i have a samsung s1030 digital 10.1 mega pic camera and am only getting two days use off a set of batterys (duracel) even using ni-mn recharagable (sony) and setting camera to this type from alkali, this is also only minimal use on holiday etc maybe 10 pics and a little looking back. it is still under warenty is it the camera. ps it is set on high res at 10.1
  • ragger75 Aug 25, 2008
    thanks, but also been in touch with samsung and they suggested using rechargables also but 2500mAh and its fine now.
    Problem Solver:
  • 5 Answers
Had same problem, now use rechargeable 1800mAh batteries and get at a months full use.
Posted on Aug 24, 2008
SOURCE:
Duracell d4 alkaline life expectancy
According to Duracell the shelf life of MN batteries is very good... It is dependent on temperature.... At say 20 deg Celcius LESS than 4% per year and at human body temperature (38 degrees) is still LESS than 10% ... But actual life may depend on the physical corrosion of the casing and be dependend on storage....
Dec 10, 2014 | Duracell D-Size Alkaline Battery Pack -...
I have buy t-10 10 mega digital camera of olympus from home shop 18 but i am not much satisfied with detalis n features of camera like which kind of batteries are best for my camera ni-mh or alkaline or...
You must use good alkaline batteries or better, a set of high capacity NiMH rechargeables. Zinc or "long life" batteries just aren't up to the task, and they can leak and cause corrosion.
NiMH batteries with a capacity of 2700mAH are available, and these will last longer, per charge, than name brand alkalines, as well as being rechargeable. You can buy these with a charger fairly cheaply now (though they obviously cost more than disposables). You will probably want two sets, one to be on charge while you use the other.
Nov 20, 2010 | Olympus Cameras
Samsung digimax S700 battery problem
Clean the battery terminals and clean the metal contacts in your camera and insert your battery and check, whether you get low battery warning.
Hope this helps.
Jan 31, 2010 | Samsung Digimax S700 Digital Camera
Is it the problems of batteries?
rechargable batteries are the way to go with a digital camera... mine just eats regular ones
Jan 03, 2009 | Samsung Digimax S500 Digital Camera
Moultrie I60 battery life.
extreme hot/cold effects battery life...also # events, whether pics taken or not 2 million gray Ark. squirrels, that never stop moving like red squirrels will use up batteries in a hurry...even still I get 3-4 mos out of 6-dcells on my I-40s
Nov 14, 2008 | Moultrie MFH-DGS-200 Digital Camera
Wont switch on
Some cameras have a bettery setting in the menu. You need to make sure this setting is set to the type of batteries you are using. Usually when you use akaline batteries and even if you put in fresh batteries but still get the low battery indication then your camera is set to rechargable (Ni-Mh). Ni-Mh has more power to it then alkaline so this is why you get the low indication.
Feb 11, 2008 | Samsung S1030 Digital Camera
Battery
i had the same problem all you gotta do is buy duracell rechargable batteries with the duracell charger and u will be able to take more pics!!
Jan 02, 2008 | Pentax Optio S60 Digital Camera
Problem with sony dsc p92 - operation and battery life
try to switch to rechargeable Ni-MH batteries, i'm not sure it supposed to work properly with Alkaline, that's why Sony supplied battery charger and their Stamina batteries with this camera
Aug 16, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Batteries always low
If you're using regular alkaline batteries that?s fairly common. If you want longer life most people purchase rechargeable nickel-metal hydride batteries and a charger. Depending on the camera you?ll get 40 or more flash images out of a charging. I have two sets, one in the camera and one in the charger. Expect to pay about $5 to $10 for a set of four and around $10 or $20 for a charger, make sure its for nickel-metal hydride batteries and not the old style nickel-cadmium. Good luck and don?t forget to rate this post.
Mar 03, 2007 | Polaroid i832 Digital Camera
Samsung S1030 Digital Camera Logo
119 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
