Question about Epson Stylus 2200 InkJet Photo Printer
Epson 2200 ink problems
We recently moved, we had our printer with us, in the proper box and shipping materials. The problem was that when we opened the box, we found ink leaking, we cleaned it. But when connecting the printer it won't print anymore, even the test after cleaning the heads is not good. What can we do?
Oscar A.
    Problem Solver:
  • 5 Answers
You can try the printer head cleaning solution at www.simplyinked.com
Posted on Oct 23, 2008
    Master:
  • 521 Answers
Get it serviced from a proper technician .the ink lekage had dameged the printer head which needs internal cleaning.
Posted on Aug 07, 2008
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Printing blank pages
The reason it wont print, is because you had air get sucked into the print nozzles and then dried up any remaining ink within the nozzles. If you put a new set of ink or the one that your having problems with and do 2 or 3 cleanings and it still does not work, the unit will need to be sent in for service.
It will either require a special cleaning from the service center, or the printhead will need to be replaced.
If you want to try something your self, not as helpful, is to move the printhead manually to the left (you will need to move the locking mechanism back to free the printhead) and fill up the cleaning area with some water. it will be a small rectangular box. fill it up with water (several drops) and the water should peak. then slide the printhead back to the right and let it sit for a few hours. do a couple cleanings, and do a test print.
thanks adi
please rate this email properly.
Apr 14, 2010 | Epson Stylus 2200 InkJet Photo Printer
Where do I find ink supply level on epson 2200 ink
Open the Epson Printer Utility, Click on the printer name if you have more than one printer then OK. Click on Epson Status Monitor at top. A dialog box will come up telling you if any ink needs to be replaced. Click on the OK button in this box and this will take you to another dialog box which will show you the amount of ink left for each color.
Mar 22, 2010 | Epson Stylus 2200 InkJet Photo Printer
My printer will not function properly and when I turn on theres n
Sir,
If the ink is added into the system too quickly, then it allows air to enter the system. Use the provided syringe to extract ink and air from the bottom of the cartridges. The ink that fills the syringe can be slowly added back into the top of the ink tank.
Also remove the cartridges, turn off the printer and reinstall the cartridges. Then you can continue printing. I suggest try to use software resetter.
Thanks Good Luck
Sep 17, 2009 | Epson Stylus 2200 InkJet Photo Printer
It cannot pass the first step
The yellow material is just to key the switch during shipping. It has no other function than that. Move on with step 2...3....4....and so on you'll see that message will go away. And the part about not connecting the printer to the computer until instructed, well that is important too. Also don't forget to remove the tape carefully from the bottom of the ink cartridges. Just take your time and you will do well.
May 15, 2009 | Epson Artisan 700 InkJet Printer
Stylus 2200, "print test page" in menu, unclickable.
- System Preferences
- Print & Fax
- Select Epson Stylus Photo 2200
- Open Print Queue
- In the top right corner of the Queue window click the Utility button
- Epson Printer Utility will open where you can check the levels and run cleanings and nozzle checks, etc.
May 07, 2009 | Epson Stylus 2200 InkJet Photo Printer
Ink jam in Epson 2200 printer
First try to print something. You never know it might work. Also you might try very carefully applying a small amount of sewing machine oil on the bar the print head is attached to then again very carefully and slowly move the head back and forth along the bar. It might just be that the bar is dirty and dry and needs a little bit of lubrication.
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Help with waste ink problem on Stylus Photo 2200 printer
Hi Beckedy;
i have a solution that may help you but I need more info. Email me at gamesreplys@yahoo.co.uk
Dec 07, 2007 | Epson Stylus 2200 InkJet Photo Printer
EPSON 2200 IS NOT PRINTING BLACKS
is your ink cartridge full and properly alligned, do you have the most recent drivers. best bet to uninstall and reinstall it.
Jul 31, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
