Question about Canon Office Equipment & Supplies
My Canon S630 printer is suddenly ignoring the top page margin, printing flush with the top of the page. The paper runs through the printer for a few inches and then backs up, which is normal, but then the top margin is ignored.
  • otterjill Mar 23, 2009
    I solved the problem by making sure there was always plenty of paper in the hopper.  I'm guessing that the gears were a little worn, and a thicker sheaf of paper made it easier for the printer to "grab" properly.  Haven't had a bit of trouble since.
    Master:
  • 521 Answers
There is a problem with the gears which pulls the paper proper allignment is required so get it serviced and cleaned properly.
Posted on Aug 07, 2008
SOURCE:
How do I fix Canon IR2200 not printing whole page. Large margins on top and cutting off bottom of page.
It sound like the paper tray is not set correctly. Probably set to landscape and trying to print portrait.
Jun 12, 2014 | Canon imageRUNNER 2200
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
I want a service manual for my canon IR2830. PLS help
Printing a page from bottom to top and the set paper margine is mismatch while printing
Oct 06, 2010 | Canon Office Equipment & Supplies
I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
May 20, 2010 | HP Photosmart C5280 Printer
How to print legal paper in 1210 printer
canon lbp 1210 printers
has a probleam a legal page setting
plese answerer legal page setting
May 11, 2010 | Canon LASER SHOT LBP-3000 Printer
Canon LASER SHOT LBP-1210 Printer how to set legal page
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties "Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
Apr 24, 2010 | Canon LASER SHOT LBP-3000 Printer
Printing Large Top Margin
check the header and top margin in your application. (word, Note pad, etc..)
default top margin for Microsoft word is 1".
also check the orientation of the printer output.
Nov 24, 2008 | Samsung CLP-500 Laser Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Printing document
Did you change the top margin setting?
Make sure that the paper size is correct in the printer settings of the control panel when you print. You have to tell it what size paper you are printing on.
Aug 15, 2008 | Sharp AL-1551CS Copier
Open Questions:
50 people viewed this question
Clive
Clive
old marine
old marine
Ekse
