Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Whirlpool dishwasher won't work at all
Mod. No. DU1055XTPSO. No lights flash. There is power to the door switch. Tried reset sequence: Hi temp./Normal/Hi temp/Normal. Didn't help. The push button door panel was replaced about 3 or 4 months ago. What do you suggest ?
  • greberting Aug 11, 2008
    I would very much appreciate it if you would read this entire post before telling me to check to see if I have a blown circuit breaker!!!
    One more time. I have a Whirlpool dishwasher Model No. DU1055XTPS0. The machine appears to be dead - no lights are visible on the door panel. I have checked to see if there is power to the unit. There is power to the unit. I tested the door latch switch to see if it was working properly. It is working properly. By that I mean power goes into the switch and, when the door is closed, power goes out of the switch. So, apparently, the problem is either in the electronic control panel or the door panel. The door panel was replaced about 3 months ago so I'm guessing that probably is not the problem.
    Since this is a newer model, there are only push button controls. There are no knobs to turn or reset. The timer is, I presume, integrated into the electronic control panel.
    New Friend:
All of the websites I have checked and the procedures I did point to doing a reset of the control panel, based according to your brand and model. Mine is a whirlpool (push the buttons Normal wash, heated dry, nor. wash, then heated dry again). That did not work for me either. Then, your only other solution is to replace the control panel (mine is $160, and given the cost of dishwashers today, it's cheaper to keep her.) A technician would certainly be a way to go about getting things fixed IF you aren't mechanically or technology inclined. That's also probably the cost to have someone come out and press a button, do a little tekky thing and voila! you still need to replace the control panel. Nope.
Posted on Oct 10, 2013
  • Whirlpool Master
  • 19,396 Answers
First of all you should remove also base cover and harness and hose assembly and check wiring connections, then there should be also a fuse, usually on control pcb, that should be checked.
Here is service manual for a similar model, check troubleshooting steps.
Posted on Aug 11, 2008
    Genius:
  • 1,665 Answers
It's circuit board/timer may also be faulty.
If your warranty has expired have a technician to troubleshoot it.
Spare part is available from link
    Master:
  • 521 Answers
Get your electronic control pannel checked by proper technician the problem is in it.
    Genius:
  • 3,422 Answers
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Aug 07, 2008
Kenmore elite dishwasher smart wash flashes
This sounds like a door switch that is faulty on your main door so the system gets a signal saying its not closed properly and there for signals fault
Dec 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
The "clean" light is flashing
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 18, 2011 | Whirlpool Dishwashers
I have a Whirpool D/W Mod. GU2275XTVYO. The clean light flashes 7 timed, pauses and flashes 7 times again... Is that in the board? It will cancel and drain but won't do anything after that. Please...
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 25, 2011 | Whirlpool Gold GU2275XTV Builtin...
Mod #gu2500xtpb1 clean light flashes 7 times
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats--
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence--
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes). You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Kenmore Elite Ultra Dishwasher and the cleaning light is flashing. I have tried pressing the start/resume button and closing the door within 3 seconds. I am not able to turn on my dishwasher. I...
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Mar 02, 2009 | Dishwashers
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher power surge results in flashing clean button
I'm not sure what the sequence would be on your particular model as Whirlpool dishwashers can differ in operaiton. However, if you remove the lower kick panel under the dishwasher door, there should be a tech sheet either directly behind the panel, or tucked inside the door. The tech sheet will list all troubleshooting tips and any fault codes that the owner/operator's manual does not list. This is the SAME sheet the repairman will reference when they come to your home on a service call. Please let me know if you still require assistance. I hope this helps you.
Oct 22, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
409 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
