Question about Maytag Kitchen Ranges
The oven pilot to our gas stove was out, while the stove top pilots were still burning. When trying to light the oven pilot, it would light but not stay lit. Model #CG31200BDW
  • what is this Aug 07, 2008
    We feel the solution is helpful, but how do we order the part?
    Brigadier General:
  • 3,614 Answers
Have you done testing and checking the unit, it seems that your problem was on the thermal fuse, and this part need to be replaced if you find it burned or busted
Posted on Aug 07, 2008
Stove pilot is on but oven wont light?
How do you know the pilot is on? Most likely if actually burning gas pilot, you have a bad oven thermostat. or perhaps valve. If your question is about the light switch itself, that is a different issue and somewhat confusing.
Feb 27, 2015 | White-Westinghouse White Westinghouse...
I am wondering how I'm supposed to light the pilot on a Hotpoint stove. I think I'm supposed to lift up the cooktop, but I can't get to lift up. It feels like its locked/screwed down somehow but I c
Hot point has 2 pilot lights on top... light them... then go to oven and light that one... it is a safety feature... no pilot on top kills the pilot in the stove.
.. since gas is heavier then air the company made sure if there was a gas leak on top that it would not be caught by oven and blow up.
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
How do you light the pilot light? if it doesn't have a pilot light how do you light it?
It could be an auto ignite stove. Check the manual. Some of the newer stoves have an electronic ignite to save on gas usage. A pilot light can burn as much as 3 gallons of gas a month.
Sep 04, 2013 | Ovens
O'Keefe & Merritt Contempo Gas Stove Oven won't light
Probably needs the ignitor replaced. http://www.handymanwire.com/ubbthreads/showflat.php/Cat/0/Number/408747/an/0/page/332
May 24, 2010 | Kitchen Ranges
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
230 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
