Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
Does not Wash
In every mode, water fills the bottom of the washer and the sensor light comes on while the water is heated. Once the water is heated, the sensor light goes out. This is normal operation up to this point.
Instead of beginning the wash cycle, the water is drained and the sensor light comes on and nothing else happens.
It is important to note that this dishwasher has two motors, a drain motor and a wash motor. Since the drain motor appears to work fine, my assumption is that the wash motor is either obstructed by a small object (i.e. glass) or is broken.
However, before buying a wash motor, it would helpful to eliminate any other possibilities.
    Brigadier General:
  • 3,614 Answers
First check if there was an object that obstruct the motor, try to clean that area, and run again the unit, if the problem was still there, then could be the washer motor was broke.
Posted on Aug 07, 2008
Washer won't fill
check to make sure your clothes are not covering the middle of the drum it has a sensor there for the water to come in
Feb 02, 2013 | Whirlpool WTW57ESVW 4.0 Cu. Ft. Top Load...
My washer seems to be stuck on a boil wash i turn the knob to another setting and the time light flashers but will not stay on and the washer start a boil wash
Possibly the water level sensor inside is out of order. So, the program only gives the command for filling with water and heating.
Sep 10, 2017 | Hoover Nextra HNT 2135 Top Load Washer
Will not start bottom of area full of water.
It sounds like the problem could be caused by the fact that the heating element, or the hot water sensor, has failed so that the washer will not proceed with the wash program until the water is up to the correct temperature. You should be able to easily tell if the element is getting hot. You could try manually putting in hot water before the washer fills up with cold to see if the wash then proceeds which will mean that the heating element needs replacement.
Sep 23, 2010 | Kenmore Dishwashers
The dishwasher fills up it starts to spray the water but after 5 seconds it emptys. It then does the other the rest of the wash normally. This happens in all modes.
Check to see if water at the base of the washer has caused the "anti flood system" to trigger. The anti flood device is a polystireene float and micro switch that does trigger (and puts the washer in pump out mode) once water via leak or spill is detected. You can tilt the washer to 45 degrees and check if a small amount of water comes out of the bottom. As you indicate that the washer emptys after 5 sec I do think that the anti flood system is causing this.
Apr 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Will not wash it syphons water in the wash mode
The mixing water valve isn't shutting of letting it come in slowly. Replace valve. If not filling up may be caused , drain hos emaybe to low to ground. Should be at least two thirds up the washer.side.
Jun 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Why does it flash F 24 when i push the button to wash??
F24 is a water temp sensor error. If the sensor reading is not within specs during the water heating portion of the wash cycle this code will come up.
1) water was too cold or hot when it filled the washer.
2) you have a bad or unplugged connection of the thermister..
3 you have a faulty thermister..
hope it helps
Sep 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Overflowing water
If the water comes out when filling, check your water valve by unplugging the washer when it is filling. If the water still runs, replace the valve. If the water stops, check the small tube that goes from the water pressure switch (in the consul) to the bottom of the tub. This must be connected without any holes or obstructions. If this is ok, replace the water pressure switch.
Jan 03, 2008 | GE WBSE3120B Top Load Washer
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
160 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
