Question about Electrolux Lux 7000 Bagged Canister Vacuum
Replacing the belt on an Electrolux Advantage vacuum
I can't get the head off. Any ideas?
I took care of it. Thanks for checking.
Posted on Aug 08, 2008
Electrolux Oxygen3 Ultra head works for 5 seconds then reset trips. I reset it and it works for 3 seconds and trips again. The beater bar is completely clean with a new belt, filter and bag. Ideas?
Try condenser if not it might be loss of electrical if in area of drop on voltage check what voltage supply you have or try a different soket hope this helps.
Sep 26, 2017 | Electrolux Vacuums
How to remove brush cover of discovery advantage upright vscume cleaner
Lay vacuum on table or other surface on it's front.
Remove the 4-5 screws on the base plate.
There may be a rectangular hole on each side of the wheels. If so, insert a standard screwdriver and rotate gently to release latches.
Carefully hold the halves together and turn vacuum onto it's back.
Lifting from the back, remove the power nozzle cover.
If replacing the belt or brush, remove the screws located at each end of the brush. Lift brush out and remove belt.
You can no replace the belt, brush, or both. I also recommend giving the insides a good cleaning before reassembling. Make sure when you reassemble, insert the lip of the cover into the slot, then close the back. Some gentle manipulating may be necessary.
Mar 04, 2011 | Electrolux Vacuums
Power head on my Electrolux Epic stopped working. Do I need a new one or could there be a part that needs replacing. Can I open it to see?
Have you tried pushing the reset button? I'd try that first. If that doesn't work it could be that the belt is broken. The motors don't go out very often on those.
Dec 04, 2009 | Electrolux Epic 6500 Vacuum
How to check the belt?
I have listed a link to the manual for your model and a link to the replacement belt you need. Hope it helps!
Manual
Electrolux Epic 3500 Replacement Belt
Oct 29, 2009 | Electrolux Epic 3500 Vacuum
How do you access the belt on the electrolux guardian
Flip the power head upside down and look for 5 black screws recessed in the bottom of the head...2 mid way back and 3 along the brush area. Once removed the lid should lift off. Be careful not to disturb the wiring harness.
The brush roll has a pulley and bearing end. Both should be cleaned and any hair or thread removed. The motor screws will have tensioning positions for the new belt so leave enough slack so the new belt depresses slightly. You will find a replacement at vac shop or thru AERUS Electrolux dealers
Oct 20, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
111 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
