Question about Hobart N50 Stand Mixer
I am trying to fix the dial on my hobart slicer any ideas
The hobart model 1712 slicer, dial is stuck about 1/2 inch down from the blade. doesn't go up or down, bought it used and everything else is in great condition, any ideas. Thanks Jason
  • 640 Answers
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Posted on Aug 07, 2008
SOURCE:
HObart MOdel 1712 Slicer Sharpener
The tw sharpener stones should be fixed with the screw provided to the blade
May 08, 2008 | Hobart A200 Stand Mixer
How do you remove the cutting blade on hobart model 410
The disc in the middle of the blade unscrews. A glancing blow with a rubber mallet will sometimes break it loose.
May 31, 2010 | Hobart Food Mixers
How to adjust the slicer attachmenton the mixer attachment
take the attc. apart on the back btm of thecutter assy. there is a hand nut loosen shaft should slide either up or down depending on the thickness you want then tighten nut
Nov 03, 2009 | Hobart A200 Stand Mixer
Hello, I have a commercial dough mixer,
it's a standard drive system found on most hobart mixers like the a200 style and you may find only hobart parts will fit it
Oct 10, 2009 | Hobart D300-6036 Mixer
Worm gear hobart slicer
What is the model number?
Apr 06, 2009 | Hobart N50 Stand Mixer
Hello...I am looking for specs for the Hobart 300 slicer....does anyone have them? I would appreicate your help...Diana [email protected] The county is requesting them as soon as possible...I...
Hi Diana. Have you given us your complete model # for your slicer?
I can't find a listing on Hobart's website for a 300 slicer. Is there a digit missing in your description?
You could call your nearest Hobart parts place and ask them to email your specs. ASAP.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 24, 2009 | Hobart Food Mixers
Service parts list of hobart mixer a120
There is a website called onesharpstore.com that specializes in food processing appliance parts. I saw the hobart model 1812 listed there just today (03/07/09). They even have a number you can call direct. 772-770-4383.
Jan 20, 2009 | Hobart D300 Stand Mixer
I want to buy some oil to lubricate my hobart slicer .what to use
If you can, remoove the blade - very carefully. Clean everything where you can. It's a virtual trash holder under the blade. Where the blade mounts, you can use mineral oil to lubricate the bearing. If it makes any contact with food, it won't hurt you.
Dec 31, 2008 | Food Mixers
Hobart slicer
Use a hammer and punch.Hit the nut in the middle of the knife to the left,unscrew then remove
Jun 09, 2008 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
652 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
