Question about HP PSC 1210 All-In-One InkJet Printer
Hp psc 1100/1200 all-in-one does not scan with vista..
Printer works but can not scan
  • 4 more comments
  • Anonymous Aug 08, 2008
    no error messages. Decided to replace.Thank you.
  • Goldilocks11 Oct 12, 2008
    My hp 1210 will print, but when i press the scan button, the on light just blinks and no scanning occurs.
    I've tried uninstalling and reinstalling with the installation disc, but that also does not fix the problem.
  • Anonymous Nov 13, 2008
    i have the same problem, it will print and copy but it wont scan. when i hit scan the light just flashes. i am using the 1200 series.
  • Anonymous Nov 25, 2008
    scan button does not function on windows xp and a hp psc 1200 series all-in-one
  • Anonymous Mar 25, 2009
    i cant scan things how do i do it
  • Mark Lou Surmeon
    Mark Lou Surmeon May 11, 2010
    Are there any error messages when you try to scan?
    New Friend:
I had the same problem. Click Start, Windows Photo Gallery, from that screen, you can select import from scanner. The 1200 series printer should be a choice to select. You are then able to preview the image or document, then press scan. I found this out through the HP support website.
Posted on Jan 11, 2010
How do i use the scanner from the all in one hp 1200 series printer? it will print and copy but wont scan.
Posted on Nov 13, 2008
    New Friend:
I have hp psc 1100/1200 series all-in-one and i lost the software and i can't use it.how can i found the software?
Posted on Nov 28, 2009
Replaced
Posted on Aug 08, 2008
3 Suggested Answers
SOURCE:
  • 72 Answers
SOURCE: Scanning with hp psc 950 on Vista
s.gif http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&cc=us&dlc=en&product=60259&os=2093&lang=en
goto this page and read the how to on using your scanner in vista. :-) Chears
Posted on Feb 18, 2008
SOURCE: HP PSC 1200 won't scan with VISTA
Use windows photo gallery....file/import photo from scanner or camera
Posted on Mar 17, 2008
Why my printer can scan but cannot print and photostat?
If photocopy and scan working only print not working then reinstall the printer driver .If only scan working then check toner level sensor and finally logic pcb.
Nov 04, 2014 | Office Equipment & Supplies
I have trouble scanning , i press scan and it prints
If the scanning operation was working before.
Turn the printer off and then back on, this will reset the printer.
The scanning opeation will then.work.
To use the scanning operation your computer must be turn on and
the printer usb cable must be connected to the computer.
Oct 13, 2011 | Canon PIXMA MP190 All-In-One InkJet...
I can print wireless from my laptop to printer but I've yet to get scan to work. When I press scan on printer it says to use computer but I've never been able to find how to scan from laptop.
Scanning normally does not work wireless. Try connecting the laptop to the printer for this function to work. Use a USB cord and make sure you set a seperate connection for this type to your printer.
Dec 24, 2010 | Computers & Internet
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan a document to my comp - I have absolutely no idea... I have tried turning it on then pressing scan - doesn't work. Tried pressing Scan when printer off - doesn't work. Tried finding the...
If will need to install the software that came with the printer. If you already did that, you can start HP directory by clicking the HP icon on the right hand side of the task bar. Then click "Scan document" or "Scan Picture" depending on what you need to scan. If you select "save to disk" option, the program will ask you where to save the file.
Oct 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
Won't scan. Copies and prints. But the scan button does nothing.
Did you try scanning from your pc? I never use the printer scan button. Most scan buttons won't work without the "print center" program open as the scan always goes to the pc. I mostly use the windows scan program in the control panel. Try this.
Jul 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Trying to scan a picture to my computer
Scarlet, I have a mid 2007 iMac and find that the MX310 does not always behave with OS X Leopard. To scan via software. Turn on the printer. Select SCAN from the printer. Press either PRINT (Black or Color) buttons on the printer. A fax - scan icon will appear in the dock and a window will open allowing you to fax. Now comes the problem. Often it will not scan the first time, I almost always get the message ¨SCAN FAILED¨ the first time I scan. Just click scan again without touching the printer will usually work. Sometimes I have to play with the settings on the left side of the scan window, switching between duplex and simplex or B & W and color and back. Usually this frees up what ever is stuck. Once it works, it works! After the scan, quit the scan and save to either a PDF or one of the photo file types (JPEG, TIFF, etc.) The results wind up in the PICTURES folder under the name of the printer and then the current date.
Jim
Jun 14, 2008 | Canon PIXMA MX310 All-In-One Printer
HOW TO SCAN ON HP PSC 1315
If you go to www.hp.com
Do a search on your printer.
Look for an option for drivers and downloads.
Select your printer and windows vista.
You need to find the print, scan, fax drivers. Not just the printer drivers.
The driver download would be like 800 MegaBytes instead of like 2 or 3 MegaBytes.
Jun 11, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
2,089 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
