Question about Gateway FPD1965 19" Flat Panel LCD Monitor
RE FPD1960 power issue
Hi I have no problem sending it to you but can you give me a quote?
Thanks
azucho98
I'm in the middle of moving so all my stuff is boxed up at the moment. If you want to send me your bad one, I can repair it for you.
Let me know.
  • 3 more comments
  • xstabless Aug 09, 2008
    my monitor works i can see the screen then it turns of,if i disconnect th video cable and recconnect it str-arts to work again,if i un plug and plug it again it works if bi turn it off on on again stay on to but then it eventualy goes to black screen
  • Anonymous Jan 12, 2009
    but i dont have a green light or anything the monitor did flash on and off at first thin just quit i can hear a sound comeing from it but no picture.
  • 83supra Jan 12, 2009
    but i dont have a green light or anything the monitor did flash on and off at first thin just quit i can hear a sound comeing from it but no picture. if it is the bord like you say where can i get one?
  • gen-i guy Jan 20, 2009
    Green power light stays on but screen is black/blank.
  • Victor Castro
    Victor Castro May 11, 2010
    Does Green light stay on when it goes black screen
    Scholar:
  • 45 Answers
USER Xstabless
Problem is your inverter on your monitor. replace it.
Some FPD's have them embedded on the power board. Replace that if its embedded.
Then your monitor should be working in great condition.
Posted on Sep 15, 2008
I got mine fixed buy a guy i found that repairs the inverter boards in our monitores for $35.00 he was fast and i am using the monitor now.
i thot i would pass on the word for yall to know where you can fined someone to fix them.
Posted on Apr 04, 2009
  • 83supra Apr 04, 2009
    he is on Ebay
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
Tip
How to setup wifi in ACER laptop
hi,<br /> <br /> Move the Wi-Fi switch to the "On" position. Not all models have this switch.<br /> <br /> <br /> Open the Windows Start menu and select "Connect To." A list of available <br /> <br /> connections will appear.<br /> <br /> <br /> Select "All" from the drop-down menu to view all available networks and <br /> <br /> connections within range.<br /> <br /> Select the desired network and click "Connect." Enter the security passphrase if <br /> <br /> prompted and click "Connect" again to join the network and gain wireless <br /> <br /> Internet access.<br /> <br /> <br /> If I could be of further assistance, let me know. If this helps or solves the <br /> <br /> issue, please rate it and give a testimonial for my response<br /> <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 02, 2011 | Computers & Internet
Powers on but only get vertical colored lines
Try to replace all of failure capacitor on power inverter board.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 27, 2011 | Gateway FPD1960 19" Flat Panel LCD Monitor
Hi, I have a problem with skype I have latest version but when i click on icon it give message " Skype has encountered a problem and needs to close. We are sorry for the iconvenience. If you are in...
sir i think when you was installing your Skype you were running the messenger
uninstall Skype
restart computer download another Skype
install it when nothing is running on background like the msn or yahoo
May 28, 2011 | Computers & Internet
I have a FPD1960 monitor that will not turn on. I
The most common problem with the FPD1960 is a failure of the power supply board pictures here.
The capacitors overheat and bulge causing them to fail. If you can solder then you can do the repair yourself. Here is a link to a parts kit: http://www.ccl-la.com/catalog/product_info.php?cPath=21_30&products_id=206
I hope this helps, if so please rate my solution.
BuddyMc
Apr 17, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
My monitor power on then cut off what can i do
I had the same problem with the exact same model of Gateway 19" LCD. Likely this is the same issue you're experiencing, and I hope you're able enough with a multi-meter and soldering iron to fix this issue, or willing enough to tear this thing down to its components and at least try to fix it.... otherwise you have a fancy dead-weight object on your hands/desk.
In my case, the 5V power was fried so I actually inserted a 5V 2A power supply inside the monitor housing and soldered the +5V and GND leads to the marked connector pins that connect the power board(larger) to the vga signal board(much smaller). I stripped the guts from the 5V power supply so it would fit easier, and then stole power from the 120v monitor input and directly wired that to the wires that were hooked to the 120v power supply prongs(after removing those prongs as well). The monitor looks and functions as if it were brand new, there's nothing extra hanging out and no bulges anywhere. It works excellent.
Aside from my more-so hackful approach, here's some links and quotes, from other sites, from people who know what components to replace on the power board and still achieve a well-working end result.
From: http://www.topix.com/forum/tech/TNTK13PFRQURRRJJC/p4
Sure-power wrote:
I repair the Gateway FPD1960, FPD1975W and FPD2185W monitors. You can contact me at sure-power@nc.rr.com if interested. If you can remove the power/inverter board it will save $$ on shipping costs. I have sucessfully repaired hundreds of these monitors. From: http://gatewaymonitors.blogspot.com/2007/09/gateway-monitor-recall.html
Russ said... Thank you Michael & Germel & everyone else for your help. I replaced the 5 470microfarad and 4 220microfarad caps on the FPD1960 and it works again. If your in the Metro Detroit area I can perform this repair for $60 onsite.
(insertabovename)@gmail.com
June 19, 2008 10:57 AM icon_delete13.gif b16-rounded.gif Russ said... russix
at
G Mail
Dot
Com
Feb 22, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor will not power on - faint flickering when the power cord is plugged in. Gateway FPD1960 TFT LCD Color Monitor
Hi
i recommend the following
1) if your monitor has a 3 pin kettle type lead, please replace and see if this sorts the issue, if it is hardwired then unfortunatley your monitor is faulty and will need to be replaced/repaired
Please leave feedback/vote if this has been useful
Feb 10, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 power issue
Let me know.
Thanks.
Jul 30, 2008 | Computers & Internet
Gateway 19 in flat monitor Model 900G
Does the power button light up or blink at all ?
It probably is the power board/ inverter. I fix many of these.
To TeeKO, did you try moving it back to see if it was maybe a bad household receptical ?
ebaysbammbammfran
Jul 29, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1965 19" Flat Panel LCD Monitor Logo
656 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
