Question about iLO DVD Recorder DVDR05
Ilo DVD player/recorder
I have a new HDTV and cannot get picture from DVD player
  • kftjr Aug 12, 2008
    having same kind of problem but the tv is an analog using a convertor. only time i can get a picture is when the convertor is switching from hd to analog
If you go from antenna to ILO to tv it WILL be analog cause the ILO has an analog tuner not a digital one. Maybe that conflicts with the HD TV.
Posted on Aug 18, 2008
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Posted on Aug 13, 2008
My ilo dvd R/P will not record and keeps saying invalid disk,
TILO DVDR04 PLAYER RECORDER THE DVD RECRDER IS IT SPECIFIC TO THE DVD RO4 CAN IT BE REPLACED WITH ANY PLAYER BURNER IT SEEMS TO PLAY NORMALLY.
Mar 08, 2010 | iLO DVDR04
Cannot record on ilo dvd recorder with any blank dvds
Try another brand of blank dvd's a -R or +R as this is a compatibly issue
If all else fails buy verbatims as they are universal
Oct 12, 2009 | iLO DVDR05 DVD Recorder
Dvd player will not play
I have had bad experiences with cheap recorders like ilo. I don't even use mine anymore. Don't wait like I did. Walmart will not take this back after 30 days so go get a new one before your stuck with it. Either do that or buy one that costs more. I think ilo is junk.
Jan 02, 2009 | iLO DVD Recorder DVDR05
Ilo dvd recorder do not recognize any dvd
According to www.dvdrhelp.com that this unit is very picky on what discs it will record on. Look up unit and read the large number of reviews in DVD Recorder section
Dec 25, 2008 | iLO DVDR05 DVD Recorder
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
ILO Recorder DVD05R - Playback jumps 10min, 20 min and more...
Does the disc still play in other dvd player? My ILO has always been picky to play rentals so I just have a cheap COBY player hooked up to front inputs of my ILO. I use it to watch the dvds, only use the Ilo to record. Saves wear and tear on my ILO but cannot find a universal remote to operate them both and my tv. If it still records okay thats what I would do, just watch the discs in a secondary unit. Sounds like time to start shopping for new recorder.
May 04, 2008 | iLO DVDR05 DVD Recorder
DVD recorder
If you are still wondering, Try here
It will tell you how.
Oct 25, 2007 | iLO DVDRH04 DVD Recorder
Dvd ilo 4
Yes yu is accidental and see the scream the new dvd yes right now and heard the picture.
Jan 11, 2007 | iLO DVDRH04 DVD Recorder
iLO DVD Recorder DVDR05 Logo
271 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
