Question about Video Game Consoles & Games
PS2 Slimline .... My PS2 is powering up ok, but is stopping at the Browser/System Configuration page. I am able to enter config and change time etc. The PS2 is making no attempt to read a disk. It is not giving any errors and is not running diagnose when set.
  • Craig Clark Aug 07, 2008
    I had suspected that the disk drive was broken, is the disk drive protected by a fuse that I can check ?
  • 6,487 Answers
You can try first resetting the console this how you do it:
There is a small black plastic rectangle on the bottom of the L-shaped reset/power board that needs to face forward and down line that black rectangle up with the clear black window on the front of the system. (The clear black window is located on the lower right side opposite where the controller ports are.)
The ribbon will be facing out the backside of the L, and plugs into the cream connector on the motherboard approx 3/4" to the left, and up slightly. The long part of the L should be resting in a slim groove on the plastic case of the system - to the upper right of the clear plastic window. There is a tiny black lever (which is the reset switch) that should be facing upward.
Hope that helps..........
Posted on Aug 07, 2008
    Sergeant:
    Champion:
  • 236 Answers
Hold the power button for at least 5 seconds. that should reset all memory.
if that does not work, use a lens cleaner.
check if the disk spins when you close the lid. if it does not, check your lid for any bent sticks.
    President:
  • 2,712 Answers
Try using a lens cleaner first... You should be able to purchase one at any electronics store. Get back to me with the results..
  • 13,433 Answers
Is the device still covered by warranty? the disk drive may have failed if it doesn't even spin the disk.
debends on where your at but
here or some parts
http://www.modchipstore.com/PlayStation-2-Repair-Parts-1-266.html
  • 1 more comment
  • Ekse Aug 07, 2008
    Does any disk work in the device? dvds`? games?
  • Ekse Aug 07, 2008
    The last time I had a ps2 (normal version) apart I did not see any fuses.
    Its connected with a few cables into the bigger mainboard. Im not sure if replaceing the lens would do the trick, but that debends if there is a circuitboard level problem with some components of the disk drive.
    Assumeing that your ps2 is otherwise in good condition replaceing the whole drive would be the best shot. if the disk doesn't spin at all it may also be that the motor inside the drive has failed, if it does spin? the lens may be faulty or just dirty and in that case cleaning the lens would solve the problem.
    Its difficult to say what the problem may actually be without actually inspecting the console.
    I think this requires some testing and would recommend haveing it examed by a local professional.
  • Ekse Aug 07, 2008
    There are no fuses between the motherboard and the disk drive
Config page on hp4345 without menu button
You would need to log into the embedded webserver to view the configuration page. From there you could screen capture it as I do not believe that the print config page was added until later models.
Oct 31, 2014 | HP LaserJet 4345mfp Printer
How to enter bios setup to toshiba dynabook satellite 1850
1. Enter BIOS Setup
1. Press the Esc key while powering on the computer.
2. Press the F1 key, when prompted.
2. Change the Virtualization Technology option
The Virtualization Technology option is in the OTHERS configuration pane on the right-hand side of page 1 of the BIOS system setup.
1. Press the O key to select the OTHERS pane, and use the down arrow key to move down and select the Virtualization Technology setting.
2. Set it to Disabled.
3. Change the Configuration option
The CONFIGURATION option is on the upper left-hand corner of page 2 of the BIOS system setup.
1. Press the PgDn key to go to the second system setup page.
2. Press the O key to select the Device Config setting and change it to All Devices.
4. Change the Display option
The DISPLAY configuration option is on the bottom left-hand side of page 2 of the BIOS system setup.
1. Press the D key to select the Power On Display setting and change it to LCD+Analog RGB.
5. Save the changes by pressing the End key and then the Y key to. Be sure not to press the Home key -- which restores the default BIOS settings.
Aug 14, 2011 | Computers & Internet
No spinning the disc in my ps2
the problem is you took it apart to quote mod it lol
Nov 26, 2017 | Sony PlayStation 2 Slimline Console
Ps2 syas browser or system configuration when i
Is the time accurate or is it off? There is a battery in the consoles that keep the time and other system settings updated when the console is off or unplugged. Over time the battery gets drained. So on older machines when you power it on, the PS2 sees that its time is off or otherwise thinks it is being turned on for the first time and makes you do the inital setup. The solution? You can try cracking open the PS2 and replacing the battery. Don't ask where the battery is located at inside it because it varies from version to version of the motherboard in the PS2. But if you search the forums, some locations have been suggested.
Jan 16, 2010 | Sony PlayStation 2 (PS2) Console
My ps2 fell and now it doesn't read discs or even spin what to do
sounds like they damaged the lazer unit.....You could take it back if its not very old. so yea buy a new one
Dec 27, 2009 | Sony PlayStation 2 Slimline Console
Playstation slimline will not let me play my games!
you have to modify first you're ps2 slimline silver so that you can play
by the way,my name is RaLpH B. cAnOn
i'm willing to help you at any time you encounter a problem to you're ps2 slimline silver
Apr 24, 2009 | Sony PlayStation 2 Slimline Console
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Browser shows no data on PlayStation 2 Console
I am having the same problem with my PS2, but I have an HDD inside of mine. I am told this is a circuit problem inside the PS2 that doesn't allow the information to be transfered to the RAM. That's why you see “No Data” instead of the usual problem of “Disc Read Error”. I hate to say it, but it sounds like you are going to have to do the same thing I am about to do. Send it in to Sony and get it repaired.
I am also pretty sure this PS2 you are talking about is the large fat one, and not the slim one.
Sep 03, 2008 | Sony PlayStation 2 (PS2) Console
MY PS2 SLIM DOESN'T spin
ok my friend is olde and slim so what we did to temporlary fix it is clean disc and put the ps2 standing up and see if it spins . if it doenst open and then spin it by hand . then try it again contact me at rockwood44@yahoo.com and have the subject
" ps2 not spinning because i am carefull bout new viruse going around on this kind of computer
Aug 23, 2008 | Sony PlayStation 2 Slimline Console
PS2 disc read error. Help Please
my skinny ps2 will not read the disc
1. it takes long
2. it says disc cant be read
Apr 06, 2008 | Sony PlayStation 2 (PS2) Compact System...
Video Game Consoles & Games Logo
32 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
