Question about Carrier Heating & Cooling
I have a carrier 50zh-036-301. it will start but a minute or two in the unit will shut off. the fan will keep blowing, but that is it.
  • 182 Answers
Could be a low pressure switch.Have a tech check your charge.
Posted on Aug 08, 2008
SOURCE:
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
Fanblade caught wire harness on carrier ac model number 50zh 636-391 think it is blue to wht, blue to white
Sounds like a replacement motor. Those wires are likely for clockwise/counterclockwise. Hook it up and make sure air is blowing out or "up". If not reverse wires.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 08, 2016 | Carrier Heating & Cooling
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
Carrier Weather Maker not blowing anything
if you turn on just the fan at thermostat does it run.
if not then the fan motor / belt / relay / start capacitor is the issue.
if your not familiar with ac then you will need help to diagnose the air handler.
belt is easy.
just take a look by opening the side access panel
Jun 04, 2008 | Carrier Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
425 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
