Question about Lexmark Office Equipment & Supplies
I have a Lexmark X4550 wireless printer connected to my HP wireless laptop via USB cable. To eliminate the cable,will I need a wireless router to use the printer?? Thanks
When all else fails, READ THE INSTRUCTIONS....MS
Posted on Aug 08, 2008
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
I HAVE LEXMARK X4550 - when I open lexmark imaging studio i am told to use the controls on the printer. This is ok when i want to scan but if I want to use ocr option I am not given the choice. I am sure...
There could be a problem with your printer software. Please insert your printer software installation CD into your computer hard drive. Execute the application to repair any possible corrupted printer software files.
Mar 03, 2012 | Lexmark X4550 InkJet Printer
I have an Acer laptop and wonder if it can be used to send items to my lexmark x4550
as long as the acer has wireless on it and that you have a wireless router to connect to it and the internet, bluetooth would even work
Jun 14, 2011 | Lexmark X4550 Multifunction Wireless Color...
I am running this Lexmark 6150 printer connected to the computer via usb cable. I have a wireless laptop, how can I print on the Lexmark 6150 from the laptop the laptop is connected to the same modem...
You can enable printer sharing on the computer where the printer is connected, then share the printer so it can be accessed by others on the network. The steps vary depending on which version of Windows the computer is running, so use the help screen. The steps will be listed for you to follow.
On your wireless computer, add the Lexmark printer as a network printer. You will probably need to install the printer drivers, so have the CD handy or download them from Lexmark's website.
Make sure both computers are members of the same workgroup, or the wireless computer won't be able to find the printer on your network. Also, the computer the Lexmark printer is connected to must be on and running for printing over the network.
An easier way to share your printer is by using a USB print server. One example is here. The server connects to your printer by the USB cable, and by an Ethernet cable to one of the wired ports on your router. Then any computer on the network can use the printer at any time.
Jan 09, 2011 | Lexmark X6150 All-In-One InkJet Printer
I recently purchased an acer computer that has windows vista. I have a hp2200dn laser jet printer and I want to hook it up by ether net into a wireless router. Unless this printer is wireless. I have a...
All you should need to do is connect the HP printer to your wireless router via Ethernet cable (which should be included with the printer). Follow the instructions that came with your printer to set it up on your computer.
May 13, 2010 | HP LaserJet 2200dn Printer
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark X4550 not printing in Vista can't enable bi-directional
"Bi Directional Printing" is a statement of Parallel Port printing. Are you connected from your PC to the Printer via the parallel port?\
Did you disconnect the USB cable form the PC and then delete the current driver prior to installing the Win 7 driver?
Nov 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
I have a wire less network set up and want to use my lexmark x1270 so i can print wireless but cable is USB and do i need to get a cable to put into my router or??
You can't set it up wirelessly, persay. but you can use a special bluetooth adapter in the "pic bridge" slot on the front. I have seen them on e-bay from £5($8) to £12($17) or so.
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
HI i have a lexmark x4550 I'm installing it on a new wireless network and computer running on xp. The sofetware installs fine but when I go to do a wireless config the computer does not recognise the...
You have an either /or situation. You can run your printer with USB OR WIRELESS, but not both. You need to decide which way you want to run and load that option.
Oct 12, 2009 | Lexmark X4550 InkJet Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
