Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Repair My unit have a cracked platsic piece near the motor. I need to know how to get the washing out to change the piece. Their does not seem to be direct access except for the bottom which is not large enough to remove the motor assembly. Thanks
  • 640 Answers
Motor coupling broke,,if you can get behind unit,,you will see 2 green clips on the left and the right..if you cant get behind unit take off front acess panel and reach though and remove.slide top forward than disconnect lid switch ,,remove top..theres 2 screws holding front panel on remove..now we can see al lthe washer parts,,please make sure unit is unpluged..remove 2 clips holding pump just grasp and pry up twist and there off ,,remove pump but do not remove hoses..just let pump hang..unplug motor connection ..remove the two screws holding the longer version of the pump clips rmove clips your done replace couping ,,revers to put together careful most of theses parts and cabnit has sharp razor edges,,use gloves
Posted on Dec 26, 2008
My Whirlpool Duet front load washing machine has been making a strange loud sound during spin cycle and gray pieces of something is left in washer and stuck on clothes after wash is complete.
HI,
You will need to have your unit inspected for damage to the front of the drum, this could be a broken spindle or something major. But without seeing the unit I could not advise you in a repair. Check for broken or cracked drum front around the inside of the unit, I suspect this could be a major issue. I would call certified repair person in your area to inspect your unit properly.
Thanks
Sep 09, 2011 | Washing Machines
GWL11 won't start at all.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Oct 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
My washing machine will not spin and the belt is not off
Get the motor checked.Its either getting weak or the motor coupler is cracked.If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.The other possibility is the transmission may not be shifting properly. If the shifter becomes even partially defective, the unit may drain the water but not spin. Thanks.
Feb 18, 2010 | GE WBSR3140DW Top Load Washer
Tub will not spin belt slips seems to be locked
Hello there:
Please follow this guide that i have provided ok
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jan 20, 2010 | Washing Machines
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
The agitator doesn't seem to agitate the clothes enough
Hi, Do you know if the lower half of the agitator is moving? Is this a two piece agitator? With the washer off, try and turn the upper half of the agitator. It should turn one direction and stop the other direction. If it turns both direstions, the agitator dog kit will need changed inn the agitator.
Please let me know if this helps you orif I can assist you further.
Vic
May 28, 2009 | Washing Machines
Does any body know of a guide detailing how to repair a cracked screen in an HP Pavilion TX2000? The screen itself is okay, but the outside plastic-type layer is cracked.
try this:
use gorilla glue and make sure you clamp pieces in place near crack after it dries scrap off expanded glue with your fingernail...
or try super glue but pen wipe off excess glue quickly and clamp near crack
Nov 14, 2008 | HP Computers & Internet
Kenmore 110.92195110
those parts come as a complete kit. order a brake assembly.
Jan 06, 2008 | Kenmore 22422 Top Load Washer
Ge top freezer refrigerator ice maker problems
most likely bad icemaker but could be a leveling issue or overfilling which both would be very noticable
Jan 04, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
DVD doesn't spin
The spindle motor could be burned out. If so, it's not worth repairing unless you could find on ebay an equivalent unit and change the part yourself.
Dec 30, 2007 | Durabrand DVD-1002 DVD Player
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
