HP Officejet 6310 All-In-One InkJet Printer Logo
Posted on Aug 07, 2008
Envelops won't print
I have a similar problem. I cannot print envelops for greeting cards. Says paper mismatch. How do I fix it?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5248
Points
This is a definitive solution for such problems.
You have to select in printing options -> paper type -> OTHER
hp printer has the ability to detect the quality of the paper, and hp developped its own standards for envelops and cards I suppose to encourage users to buy their paper products.
Anonymous
Level 1:
  • Contributor 40 Answers
  • Posted on Sep 01, 2008
Anonymous
Contributor
Level 1:
Answers
40
Questions
0
Helped
9950
Points
97
Try to check the sixe of your envelope..check on the properties if the size that you did selected is the correct size of paper the you wanted to print.try to unplug the powercable of your printer and do not press the power button just unplug it immediately.press the power button for 5 secs. and insert the power cable..try to print
send me feedback for further troubleshooting,.,.,.
1helpful
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
9helpful
3answers
Print Envelopes with hp c309a "Paper Mismatch" error
Even though the icon on the printer shows the envelopes entering the printer narrow side first, you have to set the printer up for, and feed the envelopes through, wide side first.
3helpful
I am trying to print envelopes (using MS Word mail merge) and printer says "paper mismatch"
first change the page layout setting in the document to envelop size then try to print ..... go to page layout size option the change the paper size to envelop then try to print ......
2helpful
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
11helpful
I get a paper mismatch when trying to print envelopes in Stamps.com, what can I do to fix it??
SPENT THREE HOURS DOING THE INSANE OVER AND OVER AGAIN. THEN I DECIDED TO TELL THE STAMPS.COM CONFIGURE THAT IT PRINTED A TRIANGE WHEN IF FACT THE PRINTER ERROR MESSAGE"Paper mismatch.” SHOWED UP ON THE HP MESAGE MONITOR.
I THEN CONTINUED THRU THE PROMPTS ON STAMPS.COM SOFTWARE AND CONFIRED THAT "ALL FOUR" ITEMS PRINTED ON THE ENVELOPE WHILE IN FACT IT DID NOT. THIS GET YOU THRU THE "CONFIGURE PRINTER" SETUP. THEN I SELECTED "PRINT PREVIEW" AND PRINT TEST ENVELOPE AND IT WORKED!! HOPE THIS HELPS. I HAVE NOW PRINTED 30 ENVELOPES,ALL OK.
HP J6480 ALL IN ONE PRINTER
1helpful
Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Printing card envelopes
It sounds like you may have a size mismatch in the settings. Please refer to this link for information and the settings that you need to verify. You should be able to refer to the packaging for the envelope size to select.
Hope this helps. Please rate this information.
Thanks
1helpful
Printing envelopes
If you look closely at the very front of the paper tray, just to the left of the sliding thing that keeps the paper from drifting out of the front, you will see a couple of illustrations showing how to position envelopes in the paper feeder. For regular letter-sized envelopes, or even greeting card envelopes, place them face down with the top of the envelope pointing to the left as you are facing the printer. The return address area should be away from you. Position the envelope all the way to the right side of the paper feeder, then gently slide the envelope all the way back until it is stops so that it is accessible by the paper feeder. Bear in mind that it will be flipped over when it comes out. To avoid wasting an envelope, do a trial print on a piece of paper to make sure you understand the positioning correctly. Good luck!
Printing greetings cards and envelopes
At the moment it is printing both sides of Greetings cards, but this printer appears to be very sensitive with regards to placng card in the exact position in the paper tray.
Why it will not print envelopes without smudging I still don't know, so I shall just have to write address by hand after I place graphic on the envelope
This 5300 was a Christmas gift from my wife and if I could afford to change it I would. The performance is very dissapointing
Kindest Regards
David Gray
k24674
Grand Canyon Tech
Grand Canyon Tech
