Question about Samsung Televison & Video
I have a phillips p200 computer and need to set the screen size on my samsung 32inch lcd tv to 'just scan' so it recognises without having to change the setting by remote
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
SOURCE: reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 166 Answers
SOURCE: Screen size changing back and forth on its own
Try going into the menu format setting (4.3 or 16.9 or auto) and change setting from auto to 16,9 and store setting.
SUPER8
Posted on Dec 01, 2008
SOURCE: Samsung 40" LCD HDTV #LNS4041DX/X
I the same problem and I found that the Capacitors used on the power supply portion of the circuit board were leaking and/or bulging. These parts were failing and as a result the problem worsened with time. If you are able to remove and solder new parts on to the circuit board follow the following procedures. Or get a technician to do the repairs.
1) Make note of connections at back of TV.
2) Unplug power cord and other connectors from back of TV.
3) Remove back of TV with a Phillips (+) star shaped screw driver.
4) Note the position of all connections to the main board.
5) Remove circuit board taking care not to damage any of the components.
6) Locate parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors.
7) Remove and replace parts with capacitors of equal physical size that are (1000 uf ). I would recommend a voltage rating of 25v or 32v. Note that the voltage refers to the amount of voltage the capacitor can handle. The higher the better.
8) Reinstall and reconnect the circuit board.
9) Replace back on TV and setup the unit as before and you’re done.
10) Enjoy!
I replaced the parts for just under $10.00.
Posted on Apr 27, 2009
Screw size for wall mounting for Phillips 32inch. What is the screw size on the back that you would use to mount tv to wall
Get in touch with Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Feb 28, 2015 | Philips 32PFL5332D 32 in. LCD Television
How do I get full screen on my samsung 45?
Those settings do not alter screen size, only the contrast/brightness. You need to go to the menu that alters 4:3, letterbox etc.
Sep 15, 2014 | Samsung Samasung 32inch UA-32EH5300 Smart...
How do i get better gaming graphic on samsung lcd tv 32inch
Hmm. What produces the images on the TV?
It's the video card in the computer!
Apr 11, 2014 | Samsung Ln32d403 32 in. LCD TV
I cracked my new 32inch lcd tv screen need new one
Don't know what brand it is but, it really doesn't matter the screen or lcd panel cost as much or more than a new set. Sorry.
Aug 24, 2009 | Televison & Video
I was needing codes to a 32inch flat screen tv
i need code to resent an phillips universal control
Jan 17, 2009 | Samsung TXN3245FP 32" TV
Samsung LN 53A550 Image size
you need to go into personal settings through the control panel on your computer and change screen settings for output 2. You may have to try different resolutions to fill the screen
Jan 08, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Connecting Toshiba notebook to Samsung LCD TV - small image only
because you have added a new monitor, you have to go into your graphics settings and set the screen resoloution to a setting your comfortable with
hope this helps
regards
Nov 20, 2008 | Computers & Internet
May 29, 2008 | Televison & Video
Adjusting screen size
Make sure you dont have picture cropping on in your settings. If you do, it will crop about an inch or more off all sides of your picture.
Feb 13, 2008 | Konka KDL32AT23U 32 in. LCD Television
Televison & Video Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
