I have a Dell computer. Bought in 2004. Have Sonic Now 7.3 version 7 with code of 730b56c. I have tried to burn a CD and
it says I need a driver.
Please Help!
[email protected]
Sonic RecordNow Deluxe 7.3 is an old burn software which do not need any drivers to run the program. If your New PC is running on OS Win 7, the software is not compatible with Win 7 & Vista. The version 10 is compatible.
Hi Richard, yes you can burn DVDs with your laptop. Check the CD/DVD disc that came with your computer. However, I understand its pre-installed either with Roxio or Sonic utilities. On the other hand, if you have Vista and Windows 7 it will do as well.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
there are alot of kind of cd brand, like, maxwell. princo, ech.... use the common cds or dvd brand. may this cause of cd only. not good quality..otherwise chech your cd room drive. maybe the lins can recognise try to change another cd or dvd room for testing only.. befor you buy or changing totally..
Article Details
ID Number:000131CRProducts:Easy Media Creator 9 Easy Media Creator 9 Deluxe Easy Media Creator 9 Trial Version WinOnCD 9 WinOnCD 9 Trial Version (Not available publicly) Easy CD & DVD Burning ("Vista Compatible" labeled boxes only) RecordNow 9 Music Lab Premier OS:Cause: Through a clerical error, a driver is incorrectly being blocked as incompatible with Windows Vista®. If you do not have one of the above applications, you will need to upgrade to a Windows Vista® compatible version of the software. For Dell Customers
The patch is not intended for a customer base other than Dell. If you do not own a Dell system, it is being offered "as is" and to be used at your own risk.
To download and install the Roxio DLA Update:
Click here for the DLA patch. When the file Download window appears, click Run. Note: If a Security Warning window appears, Click Run.
Follow the installer's on-screen instructions.
When prompted to restart your computer, click Yes.
The computer restarts, and the update is complete
Pleae post here again when you have more issues and ill assist you as long as it takes.
try and reinstall the sonic program if you have it. it sounds like the computer did not have the sonic software on it when you bought it, so it would have been removed when you restored your computer.
Sounds like an issue with the drive. Is your computer still under warranty? If so then I would call dell and get it replaced. If not, then I would replace it myself.
