Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Telephone plug which sky put in is faulty. as i cannot get on line or have a ring tone if plugged into it yet when i did the main socket test it all works. can someone send or come over to sort the new equipment needed
    Genius:
  • 1,269 Answers
You'll just need to reconfigure the router. Hard reset it first. Press the reset button at the back of the router for 30 seconds then unplug the power for 20 seconds then plug it back in.
Using the main computer, open your Internet Explorer and on the Address Bar type http://192.168.1.1
It will prompt your for username and password. Leave it blank on username and type admin on the password
Under SETUP tab, click the sub-tab MAC ADDRESS CLONE
Click on ENABLE and click the button CLONE YOUR PC's MAC then click on SAVE SETTINGS at the bottom.
Now powercycle your devices. Turn off router first and then modem. Wait for 30secs. Turn on modem first, wait for lights to stop blinking then turn onrouter.
That's it. You should be able to go online behind the router and the phone should also work.
Posted on Aug 08, 2008
How do I check my phone line? I have no dial tone. When The phone rings, it only rings once.
it rings so that indicates that the land line is ok
for a quick check see if you can borrow a neighbours phone and plug it into the wall socket
If you get a dial tone then , the problem is your phone
if you do not get a dial tone , call the service provider and report a faulty service
Sep 07, 2017 | Lands Phones
Panasonic cordless, no dial-tone, not ringing yet landline seems to be ok since computer is working.
although the computer and the telephone use the same line, they do not use the same system
frequency for a telephone is vastly different to adsl and it is in the exchange that the difference occurs
get ( borrow) an old phone and plug it into the socket and if you have a dial tone , it is the cordless system that is faulty
if the batteries are recommended at 1.2 vo then that is what you should be using as that is what the phone frequency will be set to use
Oct 12, 2016 | Panasonic Lands Phones
Phone doesnt have dialing tone, cant make a call also when we ring home its goes to engaged tone
This means that your phone line is short circuited somewhere.
The technical name for it is Partial line Lockout.
Try unplugging anything connected to the phone line, including modems, fax machines, house alarms etc (as faulty equipment can cause this), then try ringing home again. If it now rings, plug things in 1 at a time and ring each time to see what is causing it.
If it is still an engaged tone with everything unplugged, then the short circuit is on the phone line in the street and needs to be repaired by your telephone company.
Oct 11, 2014 | Lands Phones
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Why no dial tone??
have you plugged your new phones telephone line into the telephone socket?
Aug 01, 2014 | BT 4500 Cordless Phone - DECT - Satin...
No dial tone
indicates that the phones are faulty
the land line carries adsl and phone at different frequencies so as the internet is working so the land line is good
check that the internet and phone line is connected into the correct sockets on the line splitter before the land line connection
Nov 21, 2017 | Lands Phones
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Greetings my hp office jet its not faxing nor receiving faxes. it says no dialing tone
At a guess, I would say your phine line is either dead, or you have the line connected in to the incorrect socket. The phone line needs to be plugged into the socket that has an 'L' next to it. Check this first. If this is plugged in, check the line to the wall socket to make sure it is plugged in. If all this is good, press the hook button on the front of the unit, if it has one. You should hear a dial tone. If there is no hook button, get a phone and plug it in, if there is no dial tone, get a telephone tech in to check your line. If there is dial tone and you still can't fax. the unit has a faulty modem and will need to be replaced.
Being it a HP ink jet, should this be the case. throw it out and buy a new printer as the printer cannot be fixed because HP do not supply spare parts for their inkjet printers.
Gremlin11
Dec 13, 2008 | HP Officejet 4355 All-In-One InkJet...
Self test
not sure but if when you lift the handset do you get a dialing tone? if not usually cheaper to buy a new fax maybe the modem is faulty
Dec 01, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
BT Freestyle 2200 do dial tone
I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
Are your phones getting charged?
However,
Try putting the base station into a different phone line/ socket if you have one.
if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
