Question about Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
My bake element stopped working (after a few moments broil stopped too). I replaced the thermostat. Now Mini-broil, tru convection (with fan) work.
Not working are Maxi broil, Convection broil, bake and convection bake.
I was hoping that the new thermostat would fix it. But I guess not.
The oven is less than a year old and not abused.
I don't have an impedence tester and at this point I would just keep on replacing things.
Do you think it is the bake element, selector switch or could it be something else?
Thank you.
  • 1 more comment
  • rpayne465 Aug 08, 2008
    Great advice Tresilla! Thanks for responding so quickly to my question!
  • rpayne465 Aug 12, 2008
    Hi Techexpert12,
    Unfortunately there is no clock on this model.
    Thanks I'll give that a try. probably a lot cheaper than to try to replace the circuit board!
    Master:
  • 521 Answers
Your problem may be the bake relay on the clock or wiring.try changing that
Posted on Aug 12, 2008
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
Regards.
Mar 02, 2010 | KitchenAid Ovens
My baking element burned into. can my oven work with just the broil element or does it need both.
I don't know if the broil element will work with the thermostat -- it's usually run full on. You could experiment and see, but the oven will not work correctly with just that element. You're used to baking with heat from the bottom and there is a difference. You might get away with it for pizza and meats -- MAYBE. But, even if it does work with the thermostat, do not try to bake with it unless you plan ahead to throw whatever you're baking away. Cakes, pies, etc. will be ruined with hea from the top. Replace the element -- they're not too expensive and they're easy to change. Just turn the power off first!
Dec 03, 2009 | Frigidaire GLEB30T8A Electric Double Oven
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Dec 09, 2008 | Frigidaire PLES389D Electric Kitchen Range
Open Questions:
Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range Logo
1,020 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
