Question about Canon ImageRUNNER 1670F Copier
Canon Imagerunner replacement ram memory
I have an Image runner 2230 with a bad memory stick, specifically 256mb 133, so I buy one off the shelf, it won't work. Can you tell me what difference there is in memory sticks and which ones will work in canon IR machines?
Thanks, Larry
  • 1,219 Answers
Posted on Jan 14, 2010
  • 117 Answers
You may need to match precise speed, voltage, and timing from the original unit. The module may or may not be clearly labeled.
I do not recommend cheap commodity ram. Try using an exact replacement.
Posted on May 06, 2009
Cant access the canon image runner IR2520 error E000001
Reset the error. Press "Additional Function" then 2 then 8 then "Additional Function". Go to #CLEAR > #ENGINER > #ERRCLR.
I recommend using AVR 2000W Servo type to your machine if error persist. It is due to supply fluctuations.
Jul 03, 2014 | Canon IMAGERUNNER 2230 Copier
How to replace hard drive in Canon image runner 2230 copier
Replacement Hard Drive (LMXWM25216000) for Canon imageRUNNER 2230
Dec 16, 2013 | Computers & Internet
My canon image runner 2230 photo copier showing the error code E000002-0000 at start up.
try this solution: enter service mode by pressing *(additional function) then2 and 8 together and then again * select copier on screen>function>clear>error>ok. turn off the machine and re-start.
Jan 18, 2011 | Canon IMAGERUNNER 2230 Copier
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Image runner 2230- computer not recognizing IP adress for scanner
you must be shore that the cable between the copier and the co mputer is cross cabel and connected if there is a switch put normal cable
and then be shore that the diference between the two ip.s is smal as the computer ip
and the copier ip
Apr 28, 2009 | Canon IMAGERUNNER 2230 Copier
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
Ram Question
how old is it ? It;s possible that the total amount of memory that it supports is of 256MB
It should not matter the fact that the memorys on the slots have different sises
But u have to check u're user manual, it contains all the info. u need....
Also u can try a BIOS update ....
Jan 19, 2008 | Itronix GoBook IX250 Notebook
The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
This information can be found on Acer website.
If this solves your problem, please mark this as Solved.
Thank you
Oct 12, 2007 | Computers & Internet
Canon ImageRUNNER 1670F Copier Logo
101 people viewed this question
old marine
old marine
