Question about Dishwashers
Dishwasher confused Dishwasher was switched off just after cycle commenced (tablet had been released). On restarting dishwasher, it wouldn't take in water and has just been going through the motions of the cycle without anything happening. Even when the power button on the machine is switched off or the door is opened, the motor continues to run but without water. Water is definitely switched on under sink. I think the computer is confused - can you please help?
  • Ballanea Aug 08, 2008
    Thanks for the suggestion. We tipped the dishwasher and a little water ran out. The machine then switched on and appeared to be running ok until it was time to drain and now it won't drain at all. Have located the float. What do I do with it?
  • Balloon Boy Dec 29, 2008
    i have the same problem. what is the trick you do with tilting the dishwasher backwards?
    President:
  • 1,462 Answers
I suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Posted on Aug 07, 2008
Forget the float - as long as its not raised then its ok
can you hear the drain pump running or can you hear a low hum when supposed to be draining?
Posted on Aug 09, 2008
Selecting any programme , my Auto 3 in 1 dishwasher will only go onto a rinse cycle
reset it, switch off the mains & back on again, or you could have a problem with the tablet release. so it thinks its finished washing.
Oct 08, 2014 | Neff Dishwashers
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Dishwasher tablet not releasing into the cycle
    Pour boiling water over the panel and dispenser, it is just sticking most likely from sludge.
    Jul 09, 2017 | Bosch 24 in. SGI57M05SS Built-in...
    Asko D3230 dishwasher pump will not turn off, with main switch on
    This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
    Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
    Washing tablet found unused on the bottom of the dishwasher...
    Put the tablet in the bottom of the washer ,do a wash cycle,if the tablet is used up the washer is not releasing the tablet till the end of the wash, if the tablet is still there the water is too hard or the tablet is faulty.
    Nov 29, 2017 | KitchenAid KUDK03ITBK Built-in Dishwasher
    Tablet falls out & doesn't dissolve especially on fast cycle
    Hi and wlecome...
    You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
    Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
    SMEG DISHWASHER - SUPPLIER CODE : SA8605XTD
    Hi, I don't usually put the tablet in the door holder. I just place it in the bottom of the washer . I aways am concerned that there will be soap residue. So this way utensils are getting washed as soon a the washer commences .I usually scrape debris off plates and utensils before I put them in the dishwasher. This works well. Hope this works well for you. Teresa
    Jan 12, 2008 | Dishwashers
    Dishwasher tablet seems to be released too late in cycle
    I would check that the sump screens are cleared and wash arm holes arent obstructed.Also during a cycle check the water level of the dishwasher.Let me know if you have any other questions.HAPPY HOLIDAYS!!
    Dec 03, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
    Not Releasing Tablet
    Check if while loading dishes' you didn't blocked the detergent cup. Good luck!
    May 10, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
    Dishwashers Logo
    280 people viewed this question
    Top Dishwashers Experts
