Question about Canon Cameras
Purchased an eos50e with tamron lens 28-200mm a few years ago, can the lens be used with a digital camera
  • fredor Aug 08, 2008
    I have a mini digital but becase I have been asked to photo my step daughtere's wedding I wanted to do my best for her and hoped the tamron would be suitable with a cannon digital camera. Can you suggest a suitable alternative??
  • Canon Master
  • 13,433 Answers
For a digital SLR camera the lens needs to also be digital.
Posted on Aug 07, 2008
  • Canon Master
  • 6,487 Answers
Its compatible with this Cameras Nikon AF-D, Canon AF, Konica Minolta AF-D, Pentax AF
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 08, 2008
    This are the compatible camera for this lens Nikon AF-D, Canon AF, Konica Minolta AF-D, Pentax AF
    Good luck.............
    Master:
  • 848 Answers
Its not possible to use the lens with digital camera .........but can you be more specific about the digital camera with which you are trying to use the lens
"I also purchased a Fotodiox Lens Mount Adapter, Tamron Adaptall II Lens to Nikon Camera. The Tamron lens still will not fit
What mount do you have on the Tamron lens? (The built-in mount.) If it has a Nikon mount, you don't need an adapter at all. If it has the Adaptall mount then the adapter should fit onto the back of the lens, then the combo should fit onto your Nikon camera. If the lens has a different mount then nothing you can do will make it fit.
Does the adapter fit onto the lens?
Oct 16, 2013 | Tamron Cameras
Hello, hope you can help I purchased a Nikon D90 and a Tamron 70-300 lense about 2 years ago. The camera is working correctly, but when I connect the Tamron Lense the word err appears, in view finder,and...
Hi
Based on your description I recommend clean the CPU contacts both on the camera and on the lens.Due to dirty contacts the D90 probably won't recognize them. Try it and see.You can clean them either lens tissue moisted lightly with Kodak lens cleaning solution or carefully with Some very light amount (just moisture it ) isopropyl alchohol on a Q-tip . Just make sure and not leave any tiny strands of cotton behind.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 18, 2011 | Cameras
Please tell me the best lens and flash for D3100 i m not a proffessional photographer and i rarely go to see wild animals in forest. I want to click family photographs and natural beauty
hi there,
i used d3100 a few months ago,
for your information this camera only support autofocus with built-in motor lenses
if you have interest on wildlife, you should use tele-lens whose focal length above 200mm
if Nikon lenses cost you too much, you can choose other lenses from Tamron, Tokina, or Sigma
for family photograph, the kit lens is able to do this (18 - 55mm),
for natural beauty, i myself use nikkor 50mm/f 1,8 which has great power in low light condition
hope this will help
Jan 12, 2011 | Nikon D3000 Digital Camera
Tamron 200-500mm lens on Canon 40D ... when I put the lens on the camera I received an error message stating that ''communication between the camera and lens is faulty, clean the contacts.'' All my other...
Try gently cleaning the electronic contacts on the lens's mount with an eraser. This will remove any mild oxidation on the contacts. If this doesn't resolve the problem, then contact Tamron and ask if there are any issues using this particular lens with a Canon 40D.
Apr 17, 2009 | Tamron Cameras
I have nikon d50 camera
Yes, as long as the Tamron lens says that it is designed for Nikon.
Jan 27, 2009 | Nikon D40X Digital SLR Camera Digital...
Minolta 7000 Maxxum
The Minolta Maxxum 7000 uses a Minolta A mount, which is also used on the Sony Alpha series, as they bought out Minolta's technology. All Maxxum lenses should work for the most part on the Sony Alpha series of DSLR's, including the autofocus.
-John
Sep 15, 2008 | Tamron 28-300mm f/3.5-6.3 XR Lens for...
Will not autofocus
Hey shutterbug72,
According to the manufacturer the first thing you should try is cleaning the lens contacts with an eraser. If that doesn't work you could try removing the battery and reinserting it to reset the camera. It seems to me that if there was a compatibility issue going on you should have seen that from the start. As far as what lens you should buy both Tamron and Canon make very good lenses, but with Canon lenses you shouldn't ever have compatibility issues. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Tamron 28-200mm f/3.8-5.6 Super II Macro...
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Error 99 in my Canon 300D
You're probably right about the lens. Tamron lenses have a flexible circuit that drives the aperture blades. The aperture might need to be cleaned or the flex might be worn out. Either case needs a repair shop to correct.
Nov 04, 2006 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
