Typewritter my corrective tape came off and when you hit a key the wrong letter types on paper. how do fix this?
  • 3,594 Answers
What make and model?
Posted on Aug 08, 2008
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
Typewritter is typing different letters than what is puched.
Hold the Shift button down and then hit the Q key - this will rese the daisy will.
Nov 23, 2010 | Brother ML-100 Typewriter
Correction bar not working. When I type in a word and hit correct, instead of lifting the lettter off the paper it types the letter I typed in bold. Is there a button I can push to correct this from...
The correction tape may be installed wrong, or it may be a tacky L/o that will stick nand not raise up..
You can find a manual at BROTHER.COM, click on support.
DickyO
Sep 02, 2010 | Brother EM-530 Typewriter
Change font size on my bother ML 100
A typewritter is not like a computer. It is a mechanical device, that works by pressing an embossed letter in the daisy wheel through a inked tape into the paper.
The only way you can change either the font type or the font size is by buying and replacing the daisy wheel by another one with different font type/size letters.
To get to know more about your typewritter and accessories that might still be available to it, download Brother ML-100 Typewriter User's Manual
Click on "Go to View/Download Page" and in the new page click the "View/Download" button.
Look for page 16 (last page) of the manual for a list of cassette daisy wheels.
Aug 22, 2009 | Brother ML-100 Typewriter
Brother EM430 white ribbon broken
do you see any impression of letters on the paper when you type? if you do the ribbon not lifting or not driving. If you do not see an impression the print hammer is not firing. try to lub it with wd40 or light Wait oil. some brother typ's have a rubber bumper under the print hammer that deteriorate & need to be replaced
Oct 24, 2008 | Brother EM-430 Typewriter
Typewritter won't correct!
After you press the corr. key you must retype the wrong letter then type the correct letter.
DickyO
May 15, 2008 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Changing correction tape on swintec 2600
Be sure the corr. tape not a tacky kind, then type some thing and correct it watching the mechinism th see which one turns and in what direction. Install the empty spool on that hub thread the L/O thru the guides with dull side facing the paper and then the full on the supply hub. there may be two or more guides depending on the printer.
Hope this helps
DickyO
Apr 28, 2008 | Office Equipment & Supplies
Brother GX-6750 correctronic
Check the print wheel to see if any spokes are bent or missing, be sure that you have the proper correction tape (tack free) and that you are not in proportional space or have an international print wheel.
DickyO
Mar 16, 2008 | Brother GX-6750 Typewriter
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
44 people viewed this question
k24674
jasbo
jasbo
