Question about GE JTP45 Electric Double Oven
Oven controller My Ge double oven model JTP45b0a2bb seems to have a bad controller. I can't find the exact model number when looking for parts though. Do the numbers after JTP45 matter when finding a replacement controller?
fridgetech
  • 473 Answers
SOURCE: 326B1230P001 GE double oven
You can go to http://www3.sears.com/ or http://www.appliancepartspros.com/. You will need the complete model # from the sticker on the oven. The # listed above is not correct. It looks like a serial #.
Posted on Nov 07, 2007
rickzilla
  • 706 Answers
SOURCE: GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Posted on Sep 22, 2008
SOURCE: I have a F0 on the display of my double oven JTP45 model
Giggles01: I wish I had an answer other than calling GE. We are about to install a used oven of the same model/same vintage. I've been unable to locate a manual and need some information from it. Would you be willing to tell me the cut-out size the manual calls for regarding the installation of the oven? Most 30" ovens require a 28.5" cut-out, and I need to confirm that for the JTP45. Thank you!
Posted on Mar 23, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
  • 56 Answers
SOURCE: F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Posted on Jun 30, 2009
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
Control board harvesting
No, the parts aren't the same. The W2BB model has this code for that same part WB27T10283, while the A2BB model has this code for that part WB27T10292. The parts Look exactly the same in the diagrams, however in my past I have discovered the hard way that connectors and things in the circuitry are often different even if they fit. They're pretty pricey too 250 bucks or so...good luck!
Sep 01, 2012 | GE JTP45 Electric Double Oven
How do I find the part number for replacing control board for GE?
WB27T10290
I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
Jun 02, 2010 | GE Profile JTP56 Electric Double Oven
Replacement oven racks
The rack can be purchased from GE online or over the phone the part number is WB48X73 cost is $99.75
Feb 25, 2010 | GE JKP27 Electric Double Oven
Bake ignitor Location
ok jimmy not as bad as you think you access it through the oven cavity remove all the racks look for two screws on the bottom panel i believe they are at the front remove them then remove the bottom panel next you will see a lame spreader which is an angled plate remove it then you will see the burner bar at the back is the ignighter just match it with the new one
Feb 11, 2009 | GE Ovens
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Nov 20, 2008 | GE JRP24 Electric Double Oven
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Oven Clock
You are correct about replacing a part. there is no adjustment for the brightness. The control board will have to be replaced.
To look up parts for your oven you have to drop the 0 from the number. Try JTP45WW2WW. No one at GE has been able to explain to me why they put the zero in the model number when it is not used to look up parts. But if you leave it out on a warranty claim, they will reject it because the model number is incorrect. Go figure.
I looked it up on sears.com and repairclinic.com.
The part number for the original board is WB27K5301, but that will change to WB27T10292 that has replaced the original.
Post back if you have any questions.
Thanks/Mike
Nov 29, 2007 | GE JTP45 Electric Double Oven
Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Nov 25, 2007 | GE JKP85 Electric Double Oven
GE JTP45 Electric Double Oven Logo
183 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
