Question about HP Officejet 5610 All-In-One InkJet Printer
How to send a fax
I do not know how to fill in the "top of the page" information, and I'm trying hard to send an emergency fax. Can you help me?
    Problem Solver:
  • 52 Answers
There should be a command that allows you to SKIP that part. you put the document in, dial the fax number, and when you hear the tone, press send.
Posted on Oct 13, 2008
Lost my manual and don't know how to send a fax. Not sure which tray the document goes in. Can you help?
Directly from HP's manual on this printer:
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
For more assistance with this printer, you can go to http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=441125& and download the owner's manual. It is in PDF form, so you will need adobe reeader which you can get for FREE at http://www.adobe.com
Rose Marotta
PC ICU
Danville, Va 24541
For all your computer repair needs.
Jul 11, 2011 | HP Officejet 5610 All-In-One InkJet...
Hi, when i send a fax in this machines the page comes small. Why? Thanks
Most fax machines have to insert a name and time onto the top of the header of the page they send...this takes up a small amount of space therefore if you assume you page of information to be 100% then it has to be reduced slightly to allow this information header to be inserted on the page at the receiving end....the amount of reduction should only be down to about 95% but this is normal on all fax machines.
Jan 30, 2011 | Office Equipment & Supplies
When faxes I have sent are being returned back to me the body of the fax is being reduced in size
When you send a fax (Assume a full page at 100% )...when it is printed at the other end there is now also a "header" printed showing the time, date, who sent it etc etc across the top of the page...now you also have to print your 100% information on the page therefore to do this and still keep it on a standard 11" page...the information is "typically" reduced to about 95% so that it will all fit on the page....if the other person then turns it around and sends it back to you the same thing happens so it now could be reduce by at least 10% or more.
Nov 15, 2010 | Samsung SF-560 Plain Paper Laser Fax
Why are all my incoming faxes all black pages?? Is it my fax or the senders? Very hard on the ink cartridge
hard to determine the problem without any make/model of your fax machine. However I would begin by looking at the fax contrast and darkness settings, they are likely cranked to the dark side. If you cannot find these settings or this doesnt help. post your make/model information. I don't believe this should affect sending faxes, its likely just a print / contrast setting for received faxes.
Aug 29, 2010 | Office Equipment & Supplies
Scanning the document
I'm confused? The listed product is a Fax/Modem, not an all-in-one. It doesn't have a scan function. To send a document via a fax, you will need to scan it with a scanner (separate hardware) and then fax it. In Windows 7, a program called Windows Fax and Scan is included. If the devices are installed with the correct drivers, you can do the two steps in one program. Open the program, click on New Fax. Select Insert > Pages from Scanner (only available if the scanner was on and connected when Fax and Scan was started). Scan the document; fill in the contact information for the receipient and send. The Contact information may take a few steps since it is a Windows Contact page.
I hope this helps.
Apr 09, 2010 | Hiro V.92 56K PCI DATA FAX VOICE MODEM...
Teach me how to operate a fax machine and what are the part of a fax machine.
HI there,
Well it depends on your fax machine. If its a new version type, you should be able to simply put in the pages to be faxed, and dial the number and it sends it - and if its a long fax, then you can just leave once the fax machine starts to operate. New faxes also allow your to send and receive color faxes, rather than just black and white - pretty sweet. If its an old one, you will probably have to wait for a dial tone. When it makes a ring sound, manually start the transmission, etc, etc. Also, if people send you a fax its also very hard because they will have to do it manually too (even if they're using a new fax machine model). If you like to know more about then please follow the below link -
http://communication.howstuffworks.com/fax-machine4.htm
Please provide us the model number of your Fax Machine if you need more help or information.........
Good Luck!!
Thanks
Feb 18, 2010 | Panasonic Office Equipment & Supplies
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
5610 cannot send or receive fax
There are about a billion reasons you could be having this problem, the most common one being that you don't have a phone line plugged into the fax machine. You don't provide very much information about your problem or what you've tried up until now to solve it.
Fortunately, HP.com has a web page that should help you figure out what is going on:
Cannot Send or Receive Faxes
Let me know if this helps. If not, please post back with more information about the problem. Thanks.
Oct 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
LEXMARK X7170
Hi - You can view the manual from the link underlined in blue below:
Lexmark X7170
Changing information that appears on your fax cover page
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  2. Click View Cover Pages.
  3. Click Change your personal information that appears on this page.
  4. Make any changes.
  5. Click OK.
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 21, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Officejet 5610 All-In-One InkJet Printer Logo
35 people viewed this question
Ben Johnson
