Ryobi Multi-Volt Battery Charger
Problem for Ryobi Multi-Volt Battery Charger
Ryobi 12 V 10: 150r trimmer edger - How to remove battery
By barnes246 on Aug 07, 2008
How do you remove the battery?
Solution #1
posted on Jun 24, 2009
Not Rated)
fulcrum2009
Rank: Apprentice
Rating: 0%, 0 votes
Easy!
Just remove the screws from the housing (I had to do it this morning). There are approximately 12 screws that can removed with a flat head screw driver, all from the same side of the housing. The housing readily opens up, but be carefull, there will be some rubber strips that start to fall out. Make sure you keep these; you will need them again for the replacement battery you install. The rubber strips act as a cushion between the battery and the housing's inner ribbing; helps to reduce rattle & vibration.
Next pull the 2 electrical leads (red and black) down and off of the battery terminals, a quick **** will work well.
Lastly, your battery is 12V 8.0Ah and retails for $100 plus shipping. Mine lasted 11.5 years, but finally died (I think). You might however, want to have your battery tested to see if it really is bad, it may be a bad charger which is only $10 - $20 to replace.
Was this helpful?
Yes
No
Solution #2
posted on Apr 12, 2009
Not Rated)
pfcatering
Rank: Guru
Rating: 86%, 106 votes
just slide it back woods cheers by presing on clip ,,,,
Was this helpful?
Yes
No
Popular Solutions for Ryobi Multi-Volt Battery
Questions and Unsolved Problems for Ryobi Multi-Volt Battery
Do you recommend Ryobi Multi-Volt Battery Charger?
Answer
Answer
when i plug in the battery to recharge the two lights on the left light up and the battery does not... (More)
Answer
Yellow & Green Lights stay on. battery is fully discharged.
Answer
One of the front power jacks will not work. The motor side works great. The orthe side the gear on... (More)
Answer
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were... (More)
Answer
i get a yellow light with some batteries
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ryobi Multi-Volt Battery...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
