Question about RCA DRC8335
VCR won't accept tapes
A tape got stuck in there recently and I had to take it apart to get the tape out. The unit will not accept or eject tapes. Can something like this be fixed or should I send the unit back. I cannot even find a retailer that sells these anymore. Have they been discontinued?
    Sergeant:
    Champion:
  • 258 Answers
VHS VCRs are not being produced in very large quantities any more. You may still be able to find a combo unit DVD/VCR.
The problem may be a belt or gear, or it may be that the tray is damaged. Only a tech can tell you, but there's little point in repairing these. I know Wal-Mart still sells them...
Ken.
Posted on Aug 14, 2008
HOW DOES THE TAPE CARRIAGE EJECT AND LOAD?
go to mcmelectronics.com and order the replacement belt kit. then google your model number on alignment pdf. Your mechanism is out of alignment due to bad belts
Dec 03, 2017 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
TV/VCR combo unit trying to eject non-existent tape
The problem is that the loading is out of timing by a tooth. This would explain both the attempt to load a non-existant tape as well as the unit shutting down. This unit needs to be disassembled and the belts replaced and the loading mechanism re-timed. I have done many of these with success. While time consuming because the entire unit must be taken apart, it is not a real difficult repair for anyone that has done them in the past. Where are you located so I can make a referral?
Dan
Apr 09, 2009 | Philips Televison & Video
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
RCA DRC8335 Logo
159 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
