Question about Dishwashers
Kenwood dishwasher KDW12SL3A
Fault code E4 showsw on display and machine will not run
  • Anonymous Mar 21, 2014
    Door not closing
    Problem Solver:
  • 16 Answers
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Posted on Jan 24, 2010
Hi i have a kenwood dishwasher KS474S Slim its say e4 all the time can i fix this
Posted on Feb 14, 2010
  • markandwe514 Feb 14, 2010
    there is water coming out of it and its beeping
KENWOOD DISHWASHER KDW12SL3A KEEPS STALLING THROUGH THE PROGRAMS AND SOMETIMES DISPLAYS E4
Posted on Jan 01, 2010
This is the worst machine I have ever had! Doesn\'t wash proberly always leaves a scum on glasses , cycle takes forever , stales through cycle finishes on E3 not complete ! I think I need guide to working it which I have miss placed ? Where would I get one ?
Posted on Dec 26, 2013
My kenwood KDW12SL3A dishwasher dysplays E3 error every time I use it. dishes don't get cleaned properly. Can I fix it myself? if not how much will it cost me to get it fixed by a professional? thank you
Hi
E3 error code neans the water is not being heated to the required temperature in the machine.
This may be either a defective heating element or faulty thermostat.
It is unlikely you can fix this yourself.
Depending on what is wrong it might cost you around $150
Dec 20, 2010 | Kenwood Dishwashers
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
I have a Kenwood KDW12SL3A and have used it about 5 times and now it flashes up E1 near the end of the program. What can I do?
i had an e4 error and after lookin itup i tilted it forward after i done this i got an e1 error after playing about for a bit and checkin all hose's and connection , i came to the conclusion it was an air lock so i put on a 8min rinse mode and when it counted down to 7 mins paused it and toped up the bottom of the dish washer with boiling water from the keetle and started the rinse again. straight away you could hear the air lock movein once rinse mode fininshed i put onto a 2hr 36 min wash and is workin fine now. so make sure your machine is level and try this it may work
Jan 20, 2010 | Kenwood Dishwashers
Kenwood dishwasher
E4 means overfilled which in practice means there is water in the tray at the bottom of the machine. Lean the machine forwards and the water will drain out and clear the fault code. chances are it will fill up again so if it repeats the leak will need to be found.
Oct 27, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenwood kdw243a
The dishwasher still has water in it.  Lean dishwasher back at least 45 degrees and water should drain out through overflow pipe.  It could be caused by the dishwasher not being level.  Otherwise from reading reviews online it seems to be a common fault with this dishwasher and lots of people have returned and purchased different.
Sep 28, 2008 | Dishwashers
I have a kenwood KDW12SL3A. The Drain got blocked at the dishwasher end, and I have now unblocked and tested the drainage but have still got an E4 error come up. how do I reset this?
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
Jun 23, 2008 | Dishwashers
Dishwashers Logo
2,275 people viewed this question
Top Dishwashers Experts
