Question about Sony PlayStation Portable (PSP) Console
The L button feels and sounds like it is constantly being pressed. The characters run all of the time? Help!
  • 164 Answers
Take it to a shop,
Feel free to E-Mail me: Thomashedderwick@hotmail.com
Posted on Aug 22, 2008
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
MyWHY yakumo 55cx is constantly taking pictures without even pressing the shutter button. and I am unable to start the flash on, EV IS ALSO VERY LOW. PLEASE HELP ME
To start, you should take out the battery. Then check if anything mechanical is wrong on or around the shutter button. Press it several times and it should feel normal. Perhaps with a click. Just as you are used to feel, in the times the camera acted normal. Perhaps you should charge the battery, before placing it back, but is you are sure there is still enough power in it, replace the battery. The removing and reinserting of the battery, acts like a cold reset on a computer.
If the error returns, please visit a dealer, or a certified repair centre.
Apr 25, 2014 | Cameras
My incoming sound is extremely low . i cant hear it until i turned up the speaker . pls help me
hi i strongly recommend to go to ur nokia service provider and tell him to repair the Mic of the phone and any additional service if ur phone needs it because trying n ur own may result in some breakdown or may cause any mis-fault in the Mic so an experienced person is needed to handle the internal problems of ur mobile with care so do visit ur nokia service provider for repair and thanx for visiting fixya was this useful to u if yes pls do ate my solution.
with warm regards - bonefirediv.
Apr 18, 2011 | Nokia N73 Cellular Phone
Need dish code for remote for vizio soundbar
Hey there, this is Cheri Torres with DISH Network customerservice. I wanted to see if I could help you with the question you posted aboutthe Vizio sound bar. I was unfortunately not able to find any codes for theVizio sound bar. Another option you can try is running a channel scan to findyour code that will work best to control your sound bar. I hope that theseinstructions are useful to you. If you have any further questions or concernsplease feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Dec 27, 2010 | DISH Network IR Remote Control
Don't know how to type the third symbol on a keyboard key e.g. the little subtraction symbol on the right of the colon/semicolon is what I'm going for
Hello there brennerc.
Here's your GEEK-steer ...
Based on your description I'm not sure which character that is. Are you sure it's located on a standard keyboard? If not, it's what's known as an "extended" character, with which you'll need your Windows "Character Map" accessory to help you locate.
[Start > Accessories > System Tools > Character Map]
... or ...
[Start > Run... > type "charmap.exe" (without quotes), then Enter]
TIPS:
  • Clicking on any character's (square) will initiate a perpetually zoomed popup to help you see it better.
  • Once you find desired character, double-click (or select button) it to place it into the "characters to copy" field, where you can then "copy" (button) it, and then paste wherever desired.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed – Craig
Sep 27, 2009 | Dell Inspiron E1505 Notebook
I searching cheats for teken 3
you can get teken 3 cheats by downlading the PS2 cheatbook from the net
Jul 12, 2009 | Sony PlayStation 2 (PS2) Console
How 2 configure fax on HP laserjet 3050
If this doesn't answer your question, then let me know more specifically what you need.
Setting the time and date
To set the time and date
To set or change the time and date, use the following steps. If you need help entering any
information, see Enter text from the control panel.
1. On the control panel, press Menu.
2. Use the < or the > button to select System setup, and then press .
3. Press Menu to select Time/Date.
4. Use the < or the > button to specify either the 12-hour or the 24-hour clock, and then press .
5. Use the alphanumeric buttons to enter the current time.
6. If you specified the 12-hour clock, use the < or the > button to move the cursor past the fourth
character. Select 1 for A.M. or 2 for P.M., and then press .
-or-
If you specified the 24-hour clock, press .
7.
NOTE Make sure that you use two digits to specify the month and day, in that order (for
example, use “05” for May and “01” for the first day of the month of May).
8. Press Menu.
Setting the fax header
To set the fax header
To set or change the fax header information, complete the following steps. If you need help entering
any information, see Enter text from the control panel.
2. Use the < or the > button to select Fax setup, and then press .
3. Use the < or the > button to select Fax Header, and then press .
4. Use the alphanumeric buttons to enter your fax number, and then press .
5. Use the alphanumeric buttons to enter your company name, and then press .
NOTE The maximum number of characters allowed in the fax number is 20. The maximum
number of characters allowed in the company name is 40.
Apr 07, 2009 | HP LaserJet 3050 All-In-One Printer
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Sony PlayStation Portable (PSP) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
