Question about JVC RX-D301S Receiver
Audio Connections I have a JVC RX-D301s receiover. How can I connect the audio outputs from my cable box and my computer to this receiver in order to play through the speaker system?
  • dgoldsm Aug 07, 2008
    I have not yet looked at the manual you referred me to, but the documentation that came with the receiver does not mention an audio connection to a cable box nor does it indicate how to set up any other "auxiliary" audio input.
    For the time being I am using this receiver in the simplest possible way. I have left and right speakers attached - no surround at this point. In addition I have a simple Sony DVP-NS57P DVD player attached. Both FM reception DVD (or CD) audio work fine.
    Brigadier General:
  • 3,614 Answers
The cable box can be connected through a HDMI cable, and about your PC connected it on the Audio iN PORT
Posted on Aug 07, 2008
  • 1 more comment
  • micromaster
    micromaster Aug 07, 2008
    you will need a composite cable & a USB cable..
  • micromaster
    your cable box has a audio out plug.. this way you can connect it directly to the reciever, while the video was still connected directly on your TV.
  • micromaster
    the provided manual of Ekse here, has described / explain the possible connections through speaker system and computer.
  • JVC Master
  • 13,433 Answers
here is the user manual
http://resources.jvc.com/Resources/00/00/90/LVT1321-001B.pdf
Before I start makeing connetion suggestions can you tell me what devices are currently connected to it?
  • 1 more comment
  • Ekse Aug 07, 2008
    You can use the sound from your pc with either:
    1. by connecting the supplied wireless antenna into the back of the receaver and the usb wireless transmitter also supplied into your pc
    2. by connection your pc to the usb termina with a usb cable
  • Ekse Aug 07, 2008
    it is explained in detail in the page 12 of the manual
  • Ekse Aug 07, 2008
    Id need to know a little more about the connectors in your motorola box, does it have a model or any codes anywhere that would help me find out what kind of box you actually got?
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
WHERE IS THE AUDIO OUTPUT WHEN USING COMPONENT CABLES ON A YAMAHA RX-V571 RECEIVER
How are you hooking up the receiver to the dvd recorder? Component connections are only going to carry video. For audio, you would have to connect the cd-r output rca jacks to the recorder audio inputs.
Jan 08, 2013 | Yamaha RX-V571 Home theater receiver with...
I have my cable box hooked up with HDMI and it works great. I have my blu ray player hooked up with components (R,G,B). Im not getting audio or video this way. Can anyone help?
Keep in mind that while HDMI will pass audio with video over one single cable, the Component connectors (RGB) although being 3 cables only passes the video signal, you will also need to connect up a separate connection from your DVD player to you receiver for audio, be it analog (red/white RCA connectors) or optical
Be sure to specify in the DVD's on screen menu which audio output you choose as audio may not pass out all available connections unless enabled. You may also need to select which video output you are using.
As far as not getting video, just be sure you connections are correct (red to red) etc as this would explain the no video...
I hope this helps,
Magoo
Mar 06, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
I would like to hook up my amp to my pc or laptop what extensions do i use and what setting do i put it on to receive sound? It's a JVC RX-884V
If you computer has only analog audio outputs, you could use one of the audio components input , turntable, cassette or CD player input, for this you'll need a cable called " Y ", it's called this way because its shape, in one end you have two white and red RCA plugs which are connected to amplifier, in the other end you have a 3.5mm stereo plug that connects to your computer audio output, preferable the line audio output. If you have digital audio outputs from your computer, you can use the coaxial or optical inputs, the first requires a digital coaxial cable RCA plug both ends and the second an optical fiber Toslink cable.
Feb 23, 2011 | JVC Audio Players & Recorders
Left front and left rear speakers do not work, they produce some sound but mostly static. The "phono" rca jacks also do not work.
First off make sure that the cables you are using are functional. Also,check and verify the locations of the connections. You need an audio output from your source to an audio input at your receiver. If you run a video output from your source to an auido input on your receiver that will create strange sounds
Jan 07, 2011 | JVC RX-318 Receiver
Connecting cable to receiver
Do you mean 5 RCA audio outputs marked as FrontLeft, FrontRight, RearLeft, RearRight, Center? Unfortunately this receiver doesn't have discrete 5ch inputs (as yamaha calls it on its webpage).
But the cable box should have also digital audio SPDIF output - that is either optical (square connector) or coax (RCA usually orange). You can use this for connecting to receiver.
Mar 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Problem: Audio Connections 2
Thanks, I got your responce. Im currently looking into it.
also, what cable box you got?
Aug 07, 2008 | JVC RX-D301S Receiver
USB Wireless transmitter
the wireless transmitter use the same frequency as your wireless network and there should b a conflict. there is a way to change the frequency on the usb transmitter. once you do that, you should be ok.
Jan 02, 2008 | JVC RX-D301S Receiver
Getting no audio to game systems, pc connect won't connect
I also had the same problem when using my optical output for DBS and DIGITAL DVR/DVD.. you need to change the setting for this by on the remote changing to either analouge..rca sound input or Digital...for Optical input. The same problem cuaght me oput for a long time as well. The button is when you slide down the remote cover and the button is called analoug /digital
Dec 30, 2007 | JVC RX-D301S Receiver
Setup configuration
Have you tried to? I would need to see a wiring block. unit to unit, labeled at each unit including the monitor. I'll bet you can do what you seek to acheive..Give me more info, I'll show you how to do it.Just a list of makes,models,serial #s. If you have all this in PDF files, shoot 'em to me.I'll draw thr lines for you.
JVC RX-D301S Receiver Logo
133 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
