Question about Samsung Microwave Ovens
Microwave oven stuck on high power. Setting say 80% power does not work as it did before. Model is smh7178ste purchased 11/1/2007
  • Samsung Master
  • 9,174 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
There may instead be a stuck relay on the control board, which we repair for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Posted on Aug 08, 2008
SOURCE:
Panasonic inverter microwave
Ring Panasonic for service or spares tel:0844 844 3899 see if they can help?
May 25, 2014 | Microwave Ovens
What is the highest power setting? choices are low, defrost, medium, roast and reheat. no high???
Most microwaves run high at default, if roast and reheat are given that is your high setting, take one cup of water and run for 1 minute in each setting, the water that is the hottest is the high setting.
Mar 19, 2012 | Emerson MW8625W Microwave Oven
Microwave works but does not heat on any power setting
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 09, 2010 | Panasonic NN-S753 Microwave Oven
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
I need to know operataing procedures or the user manual for bajaj microwave oven model :2100 etc
Sir/Madam
I have purchased a new bajaj microwave oven 2100ETC from Alive star cj through tele shopping. Just after purchase this oven is not working in microwave setting. Please suggest me how to use this oven in microwave setting.
Oct 27, 2010 | Microwave Ovens
Will not heat and the truntable will not run
It's almost certainly the primary interlock (top door switch).
See this file for details on checking and replacing door switches.
You can also see the video at our site, which shows you how to access the door switches.
We have the service manual for the model SMH7178STE here, which should be pretty similar. It will also help you with disassembly.
May 06, 2010 | Samsung 1.8 Cu. Ft. Over-the-Range...
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
GE Microwave oven night light
This is a bad connection or a shorted dimming diode on the control circuit board.
We regularly repair these controllers for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
Sep 19, 2008 | Microwave Ovens
Model JVM1870SK04 Spacemaker XL1870
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
William E. Miller
[email protected]
Aug 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Dec 07, 2006 | Sanyo EM-P740W Microwave Oven
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
