Question about Bosch Washing Machines
I have a Bosch frontloader. I have had it almost 4 yrs. About 6 months ago or a little longer the tub has started to bouce terribly when washing heavy clothes such as jeans, towels, bedding. I have to stop the machine it bounces so badly and redistribute and untangle the clothes before starting it again. Sometimes this works, but most of the time it doesn't, so I take out the heavy clothes and finish washing them later. This is a pain in the **** because I have to be constantly close to the machine! And it makes a noise I can't discribe, its liking a rerrerererere constantly! What is going on?
  • 2 more comments
  • globug513 Aug 07, 2008
    How can a agitator become worn on a front loading washing machine? I thought front loaders didn't have an agitator.
    I can't believe something like is worn only after 4 yrs of washing clothes for just me and my husband!
    This repair sounds expensive. If it is, I might as well buy a new machine.
    This is only your opinion.
    I didn't think a front loading washer had an agitator. Can I get another thought on this problem?
    I am mostly concerned with the terrible bouncing of the tub. Its so bad I have to turn off the machine and redistribute the clothes. Sometimes this works, but most of the time it doesn't. So I take out the heavy clothes such as jeans and wash them alone. The machine just doesn't seem to like mixed loads of clothes although this is the way the manual tells you to load. I hate this bouncing, I feel like the machine is going to tear itself up. Plus the constant roaring noise it makes too is aggrevating which tells me something is wrong.
    I used to love this machine. I can't believe something is already tearing up. I thought Bosch was a good brand and I was willing to spend the extra $$ for quality. I hope you let others read this!
    Sounds like you are talking about a car. This washer doesn't have an agitator its a front loader!
    My husband says its always done this bouncing.
    President:
  • 2,712 Answers
LOOKS LIKE THE BEARINGS ARE GONE. yOU MAY HAVE TO REPLACE THESE..
Posted on Aug 07, 2008
    Master:
  • 848 Answers
The inside of the agitator where the transmission shaft attaches can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Large amount of water in wash tub under the wash basket in Whirlpool frontload duet
Even the new duets do have a panel. You need to lay on the floor to see 3 screws under the front. A torx bit will be needed to remove the screws. Before working on any appliance unplug it so you don't get zapped.
However, the problem is likely caused by the door being twisted. This can often be cured by twisting the door so the bottom is making a better seal against the gasket. This is assuming there is not tear or cut on the door bellows (gasket). Water tracks can normally be seen from the location of the leak. Liquid detergents change the surface tension of water an let it flow from smaller leaks so you may need to keep watch while the unit is being used.
Sep 02, 2014 | Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
Grease looking stains on clothing after washing in front load washer. Not on all clothing just certain items. Normally notice it on darker colored clothing.
that is leftover soad and down that is building up inbetween the inner and outer tub .....
frontload washer tend to wash in cold an d luke warm water down and most softner detergents are mader from animal fat means it not getting washed away so it cakes up and eventualy this cake deosit get heavy enouhk and fall and fet redeposited on yoour clothes ..... make sure you are using high efficiency soap and run a clean cycle every month with the hotest water cycle with a afrresh tablet for front load washers
Jan 24, 2011 | GE WSXH208A Front Load Washer
Washer becomes unbalances on heavy loads already replaced springs
I have same issue... My model i s FAV6800AWW. Failure Code is dC and uC for unbalance. I had replaced the clutch assembly 4 months ago (dyi) due to no spin.. it worked fine until now, where the unbalance issue is happening. For this issue, I have self tested the displacement sensor and it worked fine... I saw that on another forum that struts may have been issue.. so, I replaced the front struts. The back of the tub is hooked in by two suspension rods. The washer is leveled.. The tub spins/works when there is NO clothes in the tub... Only when I add any clothes, the tub starts to spin wildly until the displacement sensor kicks in and/or retrys or shuts things down... what's left to do??
Oct 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune Washing Machine (Front Loader) Part No. 6 2704440 Model # MAH3000AWW Serial # 25103319UF 1st. - on the inside of the washing machine, between the door and the tub, if you will,...
Main bearing failure that led to motor controller/timer failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Washing Machines
It was new 4 yrs ago. I use it every day. It had
try a big load of whites, lots of bleach and soap, use the long heavy clean , hot wash and hot rinse, this may clean it out. do this once in a while.doing small loads all the time can cause this.
Jun 27, 2009 | Washing Machines
GE Adora Frontload Washer shredding clothes
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Mar 29, 2009 | GE WSXH208A Front Load Washer
Dishwasher was leaking; now gets "stuck" 3 minutes after starting
You're describing a number of issues related to old age and maintenance. First, you've likely got a mechanical timer that is getting stuck. If the price of replacement is outside your budget for an old warhorse....
Second, in come cases, the timer takes care of water level...in most, however, there is a float or aeneroid level sensor. If it is a float...it may be clogged/jammed with detergent or debris. Located in the wash tub near the front. Clean it up. If it is an aeneroid, it has a tube going from the tub to the lower part which hooks into a 3 inch or so flat sided round item with two wires coming out. With the power off, test it by blowing and sucking on the tube. Blowing into it should open the switched leads ...sucking should hold a 'vacuum'. The pressure of water opens and closes this switch to determine water level.
Jul 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
