Question about Samsung CLP 300 Laser Printer
Faulty paper pick-up & tracks down the length of the paper
The brand new printer has a real struggle to pick up the paper. When it eventually does it, the paper comes out with 3 tracks down its length, about 1.6 cms wide. Using thinner quality paper (80gsm) improves this a bit but they're still there.
Any ideas will be gratefully received. Thanks
  • cahoaiviet Aug 13, 2008
    My samsung CLP 300 laser printer does not pick paper?
This problem is caused by a slippery paper pick-up roller. Because the paper slips, it "arrives" too late in the printer mechanism resulting in image shift or paper jam.
You can see this gray rubber roller by removing the paper tray and the imaging unit and turn the printer on his back. Sometimes it helps to "clean" the roller with some sandpaper (take care to remove all small particles!) and/or clean it with some liquid (white spirit, thinner etc.)
Adri Hankel
Posted on Aug 24, 2008
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
When printing invoices, the first page skips one line, the second page 3 lines and so on throwing all of the invoices off. Any ideas on how to fix this?
Set the page length at the printer's settings according to the real page length. If your paper is punched on it's sides, you can compute the real length knowing that the punches are 1/2 inch each other (or you can simply measure it). For more details, please specify the type of software you are using (ms-dos, windows, etc).
Mar 08, 2011 | Epson LQ-590 Matrix Printer
Printer pick-up 2 or more paper sheets at a time followed by PAPER JAM message no matter wich tray I use
I had the same problem before and was able to track it down to the rubber coated wheel used to pull out paper sheets from the tray. Over time it gets covered with fine dust from the paper so much, it does not provide enough friction to pull out one sheet properly on the first turn. When it continues to the second revolution, it takes two sheets out of the tray.
My works-got-me fix for this problem was to clean the wheel properly with a slightly damp (not soaking wet!) cloth. Best results come from gently wiping left to right, not in direction of the wheel's rotation. You will need to rinse the cloth a few times and repeat, the paper dust has a tendency to convert to a smeary goo if it gets wet, but will come off eventually.
When the rubber wheel is clean, give it time to dry properly before use of the printer again. Try to use higher quality paper, with cheap paper the problem occurs more frequently.
Oct 18, 2010 | HP LaserJet 4 plus Printer
Brand new MFC9840 won't pick paper from tray
If this is brand new, then it should be under warranty. Call the manufacturer or take it back to the store.
Aug 17, 2009 | Brother HL-2040 Laser Printer
R1800 wheel marks on print
you can try to load your paper by the back of the printer. This problem problably arrived wen you taste a new heavy paper (too heavy?)
Jan 23, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printer won't pick up paper
You are having problems with the rollers. First, make sure you are using the appropriate paper for your printer. Then with a small piece of sandpaper, brillo pad, etc. Scrape it across the rollers gently. This will create a grip so the paper can be picked up. You will need to eventually need to replace the rollers.
Don't forget to rate this solution.
Jan 14, 2009 | Office Equipment & Supplies
Paper won't feed, HP printer dock series 3
I had this problem (among many others with my printer). I found that just cleaning the front roller with a damp paper towel fixed it. Wipe it carefully and let it dry before reloading the paper. The rubber on the roller seems to lose it's ability to pick up the paper if it sits unused for any length of time, so wiping it with warm water and drying it works. Good luck. Lynette
Aug 28, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Can't get shredder to work
Please ... unplug your shredder before doing this.
It sounds like you were on the right track picking paper out of the gears. The problem is that the paper can get really jammed up in there, especially when you use the reverse.
I found that I needed to use a combination of a small screwdriver with at least a 3 inch long blade to push the jammed paper through. The I use needle-nosed plyers to pull the paper through the other side.
Hope this helps. Please let me know if it does.
Blessings,
-- Wes (wcbyers)
May 02, 2008 | Tech Solution TS-4500 Shredder
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
