Question about Epson Stylus Pro 7600 InkJet Printer
Keep getting a "wrong ink cartridge" message when setting up printer. Any solutions?
  • JDTec
    JDTec May 11, 2010
    The manual says that you need to use Epsoin cartridges. Are the cartridges Epson?
Yes the cartridges are Epson.
Posted on Nov 21, 2008
SOURCE:
EPSON STYLUS PRO 7600 Leaking ink One of my
sir the printer head of your printer is already thin... try to change the printer head...
Oct 21, 2013 | Epson Stylus Pro 7600 InkJet Printer
I have a Epson Stylus Pro 7600. How can air get in the lines?
The only reason I know is by allowing the cartridge to completely run out of ink. That is why you cannot print in black only when a colour has expired. The printer does not only use the black cartridge it uses a bit from each cartridge to ensure the nozzles stay clean.
Jan 25, 2011 | Epson Stylus Pro 7600 InkJet Printer
How can I remove the Ink Cartridges from an epson 7600 stylus pro. I lifted the locking arm but to no avail! Help :)
After the printer is powered On, Open the ink compartment on the Left hand side of the machine (Pull downward), then you'll see another small Lock (Ink Lever), raise it upward and remove them one by one.
You can refer to this manual (Page no. 38-40) http://ftp.epson.com/pdf/pro76u/pro76uu1.pdf
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 22, 2010 | Epson Stylus Pro 7600 InkJet Printer
I have an Epson Stylus Pro 7600 with a Agfa Sherpa 24M sticker on it. Baught some cartridges from Epson but I get Wrong ink message. Any way to work around this problem?
You need to either buy AGFA cartridges ot apparently you can take the chip off the AGFA cartridge and put it on a Epson or compatible. It will always say it's empty but should still work
Jun 18, 2010 | Epson Stylus Pro 7600 InkJet Printer
I have an Epson Stylus 7600 printer. Now the red ink is not not working.
Try cleaning the ink cartridges with the utility that's supplied with your printer. If you don't use your printer on a regular basis the cartridges tend to dry on the surface and need a good cleaning.
Nov 11, 2009 | Epson Stylus Pro 9600 InkJet Printer
Printer is displaying message maintenance req 0040
refix the ink cartridge after clean .it seems like your ink need replacing.
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
484 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
