Question about Samsung VP-W75 Camcorder
Samsung VP L700 Camcorder
Is it possible to get a cable to connect my camcorder to the a PC?
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Samsung VP-W95D Camcorder connection to a PC
I am sorry My friend, there is no digital output on the analog camcorders. You can however get a video capture card for your computer and connect up the video outputs and audio outputs from the camcorder to the video capture card. I have already converted all of my video tapes to DVD this way. Good Luck
Posted on Jun 04, 2007
SOURCE: Samsung VP-D361
looks like you need a new camera
Posted on Sep 30, 2008
charcois
  • 763 Answers
SOURCE: connect samsung VP-W60 camcorder to a pc
the way you can transfer your videos on your computer is by using USB cable and install the driver to your computer. You can upload your videos by saving it on ULEAD products. As far as i know you cant transfer videos from disc to your memory card unless it was been converted but you cant view or watch it on your camcorder itself only computer can play this because your camcorder is not able to play such converted files.
i will give you a step by step on your camcorder.
  • connect your camcorder using your USB cable to your computer and be sure it is ON
  • Install the cd driver camed with your camcorder. if you didnt prompt on looking for a driver then go to the add hardware on the control panel and follow the procedure there.
  • after the installation you should see the icon on the my computer labeled scanners and cameras and indicating the model of your camcorder.
  • Install Ulead Power Producer or any editing movie that you have like Windows movie maker, nero movier maker etc.. i prefer to use Ulead because its so easy to use
  • after uploading and editing your videos using ULEAD save it on any various types of videos that you like. you should see it after you want to save it.
  • burn your videos on NERO software
Hope you understand my procedures. Good Luck!
thank you for using fixya
CHARCOIS
Posted on Dec 19, 2008
robmcd27
  • 423 Answers
SOURCE: USB CABLE
Hi there. I can help you with that.  You need an IEEE 1394 cable. It's also known as Firewire (apple), or I-Link (Sony). It doesn't matter. Just go down to your local electronics store or Best Buy and ask for Firewire cable (they will know what you're talking about). That will fix you. Thanks for coming to FixYa and please rate my answer according to your satisfaction.
Rob
Posted on Feb 21, 2009
SOURCE: I have a Samsung DV-D381 MINI Camcorder. What
OK there are NO cables as such for that PC, as of normal, to get Video into this machine you will have to use either, a USB TV/Video card, and use the AV inputs. OR put a Video TV/Video Capture card into a PCI slot, and again use the AV inputs to connect via. The you will have to use the AV leads Yellow, Red & White, OR the SVHS port if available. You will also need software to record the video stream, If you camera has FireWire then you could install a FireWire Card into a PCI slot and hook you via that, you will still have to use software though. Sometimes the camera, has proprietary software to edit and work with the Video from the camera, usually via FireWire. To get said software go to the manufacturers web site, and download a copy.
Posted on Mar 15, 2010
I have Windows 7 ultimate. My Samsung Digital Camcorder VP-D 590 cant be recognise by my computer. Next step ?
Open windows Movie Maker and connect the camera to the computer with a firewire cable. Try again.
Apr 30, 2011 | Samsung VP-D590i Mini DV Digital Camcorder
Can i connect my vp-361 direct to a usb port ?there is a cable where it need a special connection to the pc
Hi Willy, i have the same problem. Im trying to connect my Samsung VP-D361 Mini DV Digital Camcorder to my laptop (Windows 7) but I cant. Is the problem with the O.S driver compatibility?
Mar 16, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
USB CABLE
Rob
Jan 25, 2009 | Samsung VP-D101 Mini DV Digital Camcorder
Samsung VP-D361
Aug 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
TRANSFER VIDEO TO PC
the samsung website has a vista update driver for this problem
Jan 25, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Jun 04, 2007 | Samsung VP-W75 Camcorder
Samsung VP-L850D
if you google samsung manual you can download a pdf manual complete
Sep 25, 2006 | Samsung VP-L750 Camcorder
Pal on SC-L700
This model will play only NTSC. NTSC is the television broadcast system used in the USA (and a few other countries) Tapes of any format than NTSC will not play properly in this camcorder.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung VP-W75 Camcorder Logo
202 people viewed this question
Top Samsung Video Cameras Experts
Tony
Pieter Vleeshouwers
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
