Question about GE Profile 20.7 cu. ft. CustomStyle Side-by-Side Refrigerator with Dispenser TPX21PRBWW
Auto Ice Maker Not Making Ice
Model: 23.6 cu ft; TFX24PR, TFH24PR, TFT24PR
Arm is straight down, no ice making. Could entering water line be frozen? If so, how do we unfreeze?
  • Anonymous Dec 01, 2008
    I have the same problem. I dont think its frozen water. Mine works sometimes and then sometimes it doesnt.
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
SOURCE: water dispenser
Disconnect the water line at the bottom front of the frig. Press the lever to dispense water. If you get water out of the line, then the water line to the water dispenser is frozen inside the door. Leave the freezer door open for a few minutes to soften the ice. Use a length of plastic line from a string trimmer to push into the water dispenser and force the ice out the bottom of the water tube.
Posted on Jan 10, 2008
  • 109 Answers
SOURCE: problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Posted on Mar 31, 2008
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
MNTECH
  • 1543 Answers
SOURCE: Ice maker only makes crushed ice
Pull the ice bucket out. Behind it you will see a rectangular hole with a rod in it. The rod should be able to move with your one finger up and down. If it does not, the solonoid attached to it is either frozen or burnt out.
Posted on Nov 25, 2008
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why is my ice maker not making ice?
Your pump is probably isn't working. It is in back of frig.
Jul 18, 2014 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
NO ICE IN FREEZER--ARM IS DOWN AND WATER SUPPLY IS ON.
Can be any of the following faulty ice maker, faulty water fill valve(it has 2 valve one for the front disp and one for the ice maker) or a frozen water line from or to the filter assembly.
Apr 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
My ice make bin is full but it's not dispensing ice cubes.
their is a wire like arm that is on the side of the maker this tells the maker to stop making ice till the ice goes down you will need to remove some if the ice and then reach in and pull the wire arm down not hart you will feel it click and stop and is a couple mins it will start making ice again if this is not the case the ice unit could be frozen in place and you will need to thaw it out then see if it works if it still does not then it will need to be serviced hope this helps
Aug 30, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
My whirlpool model # ed2chqxkb05 is not making ice, we can still use the water in the door. its not making ice. Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker does not make ice. Arm is in proper
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure thefridge coils are clean and free of dust , lint , pet hair , etc....
Aug 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
NO WATER DISPENSING FOR ICE
did you clear out the fill tube in the freezer section that lets the water enter the ice maker, it could be frozen
it the line and the tube are clear then replace the water valve
May 11, 2008 | Kenmore 26.0 cu. ft. Side-By-Side...
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerators Logo
146 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
