Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
How do I shut off PIP on my Sony Trinitron XBR TV?
I want to remove thePIP from the lower right portion of my screen. Can you advise?
  • dubjuac Sep 14, 2008
    I have a sony trinitron model kv-29xbr85 tv and I can't turn off the pip in the bottom right of the screen. I do not have the remote that came with the tv
  • Anonymous Oct 14, 2008
    How do I shut off PIP on my Sony Trinitron XBR TV? problem, and notify you when a new solution is offered.
  • 586 Answers
SOURCE: 32 xbr vega trinitron PIP wont turn off
Just press any channel number and PIP will disappears :)
Posted on Dec 25, 2007
  • 7 Answers
SOURCE: PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Posted on Dec 28, 2007
  • 83 Answers
SOURCE: I have a sony trinitron XBR 32 inch... The pip was
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Posted on Oct 20, 2009
  • 8457 Answers
SOURCE: Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
Posted on Jan 15, 2010
Testimonial: "Thank you FixYa. Much more helpful than SONY has been! Sony's only advice was to unplug unit and try plugging it back in.Why didn't I think of that!?"
pgh_pa_guy
  • 2992 Answers
SOURCE: sony trinitron xbr screen periodically goes black
Sony sets have several protective circuits that blank the screen if something happens that might damage the picture tube. One of the more common causes is trouble in the vertical output circuit. Given the age of your TV (the XBR models have been around a while), this might also be a symptom of a picture tube starting to fail. Most of these sets have circuitry (called AKB) that adjusts the color drive signals to the picture tube to keep them balanced. If one of the colors is enough out of range the screen will blank. It might be the tube itself, or failure of some part in that AKB circuit. The set might also have defective parts in the input switching or video processing stages.
Unfortunately, I can't suggest any place you might look if you want to try repairing this on your own. This kind of trouble usually needs to be diagnosed and repaired by a professional TV technician who has the service information to track it down.
Hope this has been helpful. Thanks for using Fixya!
Posted on Feb 20, 2010
Testimonial: "It sounds like you know what you are talking about."
My tv is a sony xbr. somehow we got ourselves a black box (small) in the lower right hand corner. The remote doesn't have pip and we never used the pip. but i cannot get rid of this box. i tried to reset...
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Oct 21, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have a Sony trinitron XBR and I can't get the PIP turned off.
Aug 23, 2010 | Sony KP-53XBR200 53" Rear Projection...
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
As I said before I have a 1998 trinitroin xbr that I do not have the remote that came with the unit and I have a black screen on the lower right corner which or assume is part of the picture an picture how...
try to obtain a Universal Remote Control and be sure that the remote control have PIP button. You will kill two birds with just one stone, solved problem and remote control.
Mar 05, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony Trinitron XBR TV, picture-in-picture got
Dec 24, 2009 | Sony Televison & Video
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Dec 25, 2007 | Sony KV-36XBR400 36" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
225 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
