Question about Mitsubishi WD-82738 DLP TV
TV (wd-82738) shuts down unexpectedly and fast flashing green light comes on This occurs about once a week.
  • Anonymous Mar 24, 2014
    inputs false
  • Mitsubishi Master
  • 8,457 Answers
The tv flashing green light is on it have a word"LAMP"writing on the tv frame?Yes,than the tv projection lamp life it is ending.Tv unexpectedly shutdown the tv also have clicking noises sound too?That the board call the Ballast board is dying too,this board only job are only to ignite the projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp and might have also have to replaced the Ballast board too.
Posted on Apr 13, 2011
SOURCE:
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Mitsubishi tv wd-82738 no power
Most of these TV's have switched mode power supllies that run very hot. There is a likely chance that the capacitors have cooked (burst) on the PSU board. They are common capacitors. Open up the TV and with the mains electricity turned off, check the 'X' on top of the tubular capacitors. If they are bulging, rather than flat, then unsolder them and replace them.
I've repaired many of these sets because of this problem.
Nov 16, 2013 | Mitsubishi WD-82738 DLP TV
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
TV Shuts down
convergence amp IC's i would start with.
Dec 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-82738 DLP TV Logo
580 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
