Question about Gateway Computers & Internet
Dvd tray on my Gateway 560GE Desktop keeps popping out
    Sergeant:
  • 395 Answers
Try uninstalling CD/DVD burn software?
Posted on Aug 07, 2008
WINDOWS 7 NOT RUNNING FOR MY PC
Please tell what error your PC shows or what problem ou faces... i might help you in this one
Sep 16, 2012 | Gateway 560GE Intel Pentium 4 531 3GHz /...
Cd dvd drive won't open. cd was shattered inside.
Look for a small pinhole just under the tray door. This is the manual release for the dvd tray.
Just insert a long needle like object into the hole about 2 or 3 inches and push.
This should pop out the tray.
You should then be able to remove the shattered pieces of disk. If the drive tray does not function normally after removing the disk pieces you may have to remove the drive entiirely from the case in order to shake out the smaller bits. If the problem persists after that, you may have to remove the metal case from the drive itself and clean it out or it may just be time for a new drive.
Good luck and please comment back if this was helpful and with how you make out.
Jan 30, 2011 | Gateway GT5428 PC Desktop
The dvd tray is stuck and wont activate
switch off the computer, locate pinhole near the dvd tray, insert lengthy pin or nidle and push, the tray will pop out, move the tray in and out 3 - 4 times and switch on the pc. most of the cases this will work fine. best of luck.. and keep smiling
Jan 15, 2011 | Dell Dimension E521 PC Desktop
The dvd player will not open on my gateway sx2800
use a opened up paper clip, push it into the hole under the cd tray to manually open the tray. If it continues to read dvd's use it else change it
Dec 27, 2010 | Gateway SX285001 PC Desktop
I forgot my password to my computer..
It's called ophcrack, download it on another computer and install on a CD or USB, then boot it from the computer in which you lost your password.
Sep 28, 2010 | Gateway 560GE PC Desktop
What mb to update from kk266plus for modern pc
you can buy DG31PR,GL / DG45PR these series mother board but you have to change your processor too with core2 duo 2ghz series, if you want to upgrade the RAM to 4GB means this is the only way have to change the following specifications (DG31 or DG 41 series board, core2duo procc,SATA seagate hard disk 500GB, 4GB RAM) this is the complete solution .
Oct 20, 2009 | Gateway 560GE Intel Pentium 4 630 3GHz(HT)...
My cpu will not power up the blue light just flashes when pushed and held
Flashing power light is a sign of a hardware failure. First unplug the pc and give it about 30 seconds then turn it back on. If it goes back to a blinking power light you have a hardware issue and will have to get that checked out.
Jun 22, 2009 | Gateway 560GE PC Desktop
My computer house dvd tray will not open up.
Near to eject button you can find a tiny hole ..insert a paper clip into it ..then the tray will eject...
Feb 28, 2009 | Gateway 830GM PC Desktop
Tower tray ejects
If you have any cd/DVD burn software tryin re-installing it.
Check your antivirus is up to date and run a full scan
Aug 07, 2008 | Computers & Internet
Dvd tray keeps popping out
Do you have any DVD burining software installed?
If so, you could try uninstalling it and see if the problem goes away?
Do you get the same behaviour when you right-click on the DVD drive icon and choose 'Eject'?
Aug 07, 2008 | Gateway Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
