Question about Vulcan Kitchen Appliances - Others
When burner goes out, so does pilot
Looking for wiring schematics on tk45. When fire goes out, pilot goes with it. This was bought from auction buy one of our customers. I'm not sure if they tried to wire it or what.
If the fire is going out and the pilot is going with it you may have a problem with the gas valve or it could be as simple as you may be getting too much air which causes too much extinction pop which will make pilot go out on occasion. You may need to adjust your primary air.
Posted on Aug 12, 2008
SOURCE:
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
Gordon-Ray overhead radiant heater that won't go into high fire
Is this a standing pilot unit. So when it goes into high
fire is it just actually going from pilot to burner on ?
If this is the case and the burner shuts down, then
it is the flame sensor.
If it is two stage heat and 1st stage is fine, then when
second stage comes on and goes out, I would be looking at the supply of gas.
Jan 24, 2010 | Heating & Cooling
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pilot will lite but burners will not kick on - Jandy lite 2 400,000BTU pool heater Me too.. was able to fire it up by tinkering with the switch that goes from "Pilot" to "On", but doesn't always work. A...
No, do not mess with wiring. If the gas does not ignite and the pilot goes out, The thermocoupler is faulty. This is the probe that should be sitting at the tip of the pilot flame. When it gets hot enough it allows the main gas valve to open when you put it to ON position. If the pilot light goes out, It shuts off the gas for safety. Summary, Bad thermocoupler. Easy, inexpesive repair. Let me know please, if you need further help.
May 28, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Gas boiler won't stay lit!
The burners and pilot need to be cleaned.
Turn off gas and power, remove the burners and pilot. Clean with a brass wire brush. (Steel wire can be used but very carefully) Remove all rust dirt etc. reinstall and it should fire right up.
Dec 28, 2008 | Ruud UBHC Air Conditioner
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Kitchen Appliances - Others Logo
136 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
Marvin
Marvin
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
