Question about Samsung DVD-V5500 DVD Player/VCR
I want to print instuction
I want to print instruction for my dvd-vhs combo .
Name Samsung # v5500
  • brncjck Oct 10, 2008
    need a manual for samsung dvd v5500
  • dnsgry Jan 18, 2009
    I need a manual for my Samsung V5500. I have lost mine. I found one site where I can get one for 15.00 but I don't want to pay for one. I just want a replacement for mine.
How to hook up to a sharp tv..nothing seems to be working and what cables do you need to hook up
Posted on Feb 22, 2009
6ya staff
SOURCE:
Re v5500 . . . can i copy a movie from the vcr onto a dvd with this model???
You cannot transfer VHS to DVD on this model unit by itself. You can, however, connect the AV outputs of this unit (as a VCR) to the respective AV inputs of a separate DVD recorder - using yellow-white-red RCA cables - as long as the source tapes are not copy protected, and the appropriate disc formats for the DVD recorder are used.
Apr 20, 2011 | Samsung DVD-V5500 DVD Player/VCR
I need the directv remote control code for samsung dvdvcr combo dvd v5500
try these...20739,20490,20573,20744,20199,20820,20899, 21044,21075,
Nov 08, 2009 | Samsung DVD-V5500 DVD Player/VCR
Dvd recording
The Samsung DVD V5500 is a DVD/VCR Combo.
The DVD is play only & the VCR can be used as a recorder.
For more information please visit Samsung
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Nov 04, 2009 | Samsung DVD-V5500 DVD Player/VCR
VHS won't play
If it's showing a welcome screen, the DVD is on. The VHS won't show a welcome screen. Some machines are a little tricky because they want to start in the DVD mode. I would concentrate in that area.
Oct 09, 2009 | Samsung DVD-V5500 DVD Player/VCR
LIKE TO PRINT OUT OWNERS INSTRUCTIONS FOR SAMSUNG DVD V5500 REDORDER
Download from
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=479722&CDCttType=UM&ModelType=&ModelName=DVD-V5500&VPath=UM/200507/20050704134129328_00593C_DVD-V5500_XAX.pdf
It's a PDF file, so you need Adobe reader or something similar.
Sep 04, 2009 | Samsung DVD-V5500 DVD Player/VCR
I have lost my instructions on using my Blue Ray. Where can a get a new users manuel?
hi friend,
go to website
www.usersmanualguide.com/samsung/dvd_player__dvd.../page4 -
thank u for using fixya
regards,
sivaranjini
Aug 12, 2009 | Samsung DVD-V5500 DVD Player/VCR
Samsung v5500 dvd combo problem
When you get a whirring sound, some click and disk not engaging on some disks, and not others , that is because lens cannot read the inital track on the CD/DVD.
This is either because disks are scratched , dirty or ruined by light and heath, or because the lens is dirty.
Try using a lens cleaner like the ones here.
If that does not work, then the unit must be taken apart and the lens cleaned with cotton buds and isopropyl alcohol.
See :
How to Clean the Laser Pickup Lens on your DVD Player
Jan 01, 2009 | Samsung DVD-V5500 DVD Player/VCR
DVD VCR combo has no power
I found out what the issue was with my Samsung DVD-V5500. It was the rectifier diode on the 15V tap of the high frequency transformer. This is the same issue that someone else with a later model V5600 had talked about. The diode had shorted and behaved like a piece of wire.
Seems to be a bit of weak point in the power supply. The issue can be diagnosed by using a multimeter to measure the resistance between the diode cathode and ground. If the meter is measuring 1 Ohm between the cathode and ground, your diode needs replacing. I just replaced it with a UF4003 diode from Jaycar, which is basically an Ultra Fast 200V 1A diode suitable for switching the high frequency (20-30kHz) output from the transformer.
The diode is located at the rear right hand corner of the board on the output of the power supply section. A picture below shows the new diode between orientated east-west between the large capacitors. The original diode that failed was an SHG2D SHS.
Sep 04, 2008 | Samsung DVD-V5500 DVD Player/VCR
Samsung V5500 DVD VCR combo, blinking led, rest is dead
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 24, 2017 | Samsung DVD-V5500 DVD Player/VCR
Samsung DVD-V5500 DVD tray intermittently wont open
Sometimes the loading belt can cause this problem or else have seen the tray in switch assy cause this as well.
May 23, 2007 | Samsung DVD-V5500 DVD Player/VCR
Samsung DVD-V5500 DVD Player/VCR Logo
111 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
