Question about Cameras
Door to battery compartment needs replaceing - Cameras
  • palxrh1 Sep 17, 2008
    Faulty battery comartment door on my Mustek- 4000
    Could maybe fix myself if could get part but happy to send and let others do
    R
    [email protected]
  • randy_craig2 Dec 08, 2008
    The latch on the battery compartment door has broken off from the door itself so now the door will not stay closed. The door is a plastic piece and the latch that broke off is also plastic. The camera is a Nikon Coolpix 5600.
    Problem Solver:
  • 38 Answers
Pl. give us the model no. We have SONy DSC-W1 Battery Door in stock.
Regards,
Sharmila.
Posted on Aug 09, 2008
SOURCE:
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
ReplacementdoorA570cannonpowershot
Hi
If you are looking for a replacement door for the battery compartment of you camera i would suggest the following.
Simply search for a Faulty Cannon power shot A570. Faulty ones sell for a lot cheaper. Then just replace the doors of both camera. Ebay is a good place to look.
Jul 21, 2013 | Cameras
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
I want to replace the cr2 battery.Where is the battery compartment for the Intermatic model ST01 self adjusting wall switch timer?
The battery compartment is located behind the pull-down door
Pry open the door with small screwdriver of fingernail file
http://waterheatertimer.org/ST01C-program.html#battery
If the battery goes dead on the Intermatic ST01C or EJ500, the screen will not display.
When replacing battery, wipe clean all the terminal points for battery and battery carriage
If the new battery does not restore the screen, then the timers needs replacement.
http://www.aplussupply.com/intermatic/timer.htm
Nov 03, 2010 | Electrical Supplies
Broken door to battery compartment
Here's a possible source, though I'd check to see whether the battery covers for the ist and the *ist are the same.
http://uscamera.com/istd.htm
Jul 05, 2010 | Pentax *ist DL Digital Camera
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Door problems
i need the battery door for my camera because its not working anymore , hope you give me a quick answer
                                                               greetings
Aug 15, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
Cameras Logo
501 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
