Question about HP Office Equipment & Supplies
My hp photosmart 7900 series printer all of the sudden will not recognize my digital camera memory card. I have tried several different cards and none of them is recognized. I unplugged the printer but that did not help.
    Master:
    Sergeant:
  • 398 Answers
The same thing happened to my photosmart 8450, so I went to ebay and bought one of those download devices for less than ten dollars and it works just great. Takes all the cards, and seems to be trouble free.
Posted on Aug 07, 2008
Using 2gb card but camera says 'use 2gb or smaller'
You may try formatting the card with the camera itself. This may allow it to use it depending on the camera.
HP Photosmart Digital Cameras Memory Cards Types and Troubleshooting
Format instructions are on page 10
http://h10032.www1.hp.com/ctg/Manual/c00891822.pdf
Aug 14, 2016 | HP PhotoSmart M437 Digital Camera
All of a sudden I'm getting a msg saying the card has the wrong format, & when I try to format it, it says it can't....
This is probably due to a bad memory card-- try using a different memory card. If you have the same problem with a different memory card, then the issue is with the camera itself. This would probably not be something that is easily fixed by a camera repair shop, as they would end up replacing the faulty component entirely, whether it be the camera, or the card.
Best case scenario, it's a bad memory card.
Mar 06, 2011 | HP Photosmart M525 Digital Camera
I cannot Format the memory card on my camera,HP photosmart M627. Can you help?
Try to get hold of a usb card reader that support your memory card and format it on your pc, both the camera and the card reader is using the FAT 32 File System to format. The one i use is a Transcend RDP8 and can take five different cards
Dec 11, 2010 | HP PhotoSmart M627 Digital Camera
PNY Optima SD HC Card cannot be read in HP Photosmart 8150 printer.
  1. Verify that the printer is turned off.
  2. Remove the Secure Digital memory card from the printer.
  3. Examine the Secure Digital memory card:
    • Is the lock switch in the unlock position?
    • Are there any visible discolorations or defects such as crack or nick in the card?
    • Are there any contacts missing from the end of the card?
    • Are there any deep scratches in the card contacts?
    • Is there any heat discoloration on the card? NOTE: If all of the above questions result in No , proceed to Step 4.
  4. Check if the HP Photosmart printer supports the file format. NOTE: In order to know which file formats are supported by the different HP Photosmart printers, please refer to the manual of your printer.
  5. (Saving the pictures on the PC, if possible) Insert the Secure Digital memory card in the camera (or another device) and format it following the proper instructions to perform it.
  6. Capture an image.
  7. Review the image. If the image is corrupted or an error such as Unsupported Image File is displayed, the Secure Digital memory card is suspected to be defective and should either be replaced or referred to the manufacturer for further troubleshooting.
  8. If the images are read properly, turn on the printer. Insert the Secure Digital memory card in the Secure Digital slot.
  9. If the printer display continues to show the Card Not Recognized error, try using another Secure Digital memory card, if one is available.
  10. If the printer is still unable to read a functional and compatible Secure Digital card, contact HP to obtain additional troubleshooting information.
Oct 05, 2010 | PNY 4GB Secure Digital High Capacity...
Reformatting sd memory card for canon camera an 8gb card and it told me I coudn't print pictures on my HP photosmart 380 series printer unless I reformatted my memory card??
If your camera is indeed an SD200, am sorry to say an 8GB SDHC will not work in this camera. The camera will fail to recognize it, and will do this by giving various problems as you've run into. The overall problem is that the camera was designed before the SDHC format came out (SDHC cards although the exact same in appearance are different in format than standard SD cards). The largest size card that the SD200 will recognize is a 2GB standard SD card.
Jun 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
How do I reset my HP photosmart digital camera R742 to read the memory card. It's not reading it.
Try another memory card. It can be that the memory card stopped working. Also check if the tab on the card is not in the locked position.
Once you checked this, then I will conclude it is the camera. Are you able to insert the card so that it stays in without it trying to pop out? Maybe that one of the pins in the card reader is bent. This prevents the camera from recognizing the card.
Jun 05, 2009 | HP Photosmart R742 7.0 Megapixel Digital...
Cannot delete images in the camera.
Check the card and see that the little slide switch on the side is moved to the unlock or clear position. You try to delete images off another card to see if it is the camera that is defective. Is it still under warranty?
Jan 20, 2009 | HP Photosmart 320 Digital Camera
Menory card unreadable etc.
ok check the card slot for the memory card the pins are bent... for shore
Sep 03, 2008 | HP Photosmart R707 Digital Camera
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart M22 Malfuction
use different memory card, most troubles i always encountered in digicam are caused by memory cards, many cards works in pc but not in digicam. hey tapping side by side always takes away the trouble. [;0)
Jun 21, 2006 | HP Photosmart M22 Digital Camera
75 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
