Question about Dryers
Kennmore clothes dryer
Our dryer does not shut off after the cycle has been completed.
Dryer runs but does not heat
Posted on Jan 27, 2009
It makes a ringing noise when it is running
Posted on Aug 30, 2008
SOURCE:
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
My kennmore dryer model # 11062912100 won't heat up what is the possible cause?
check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
May 05, 2014 | Kenmore 62602 Electric Dryer
Kennmore 70 series drier mod 110.6675201 I have to run it throw 2 cycles to dry the clothes
venting issue #3:
http://www.applianceaid.com/general.html#vent
Feb 16, 2011 | Dryers
I was using my kennmore dryer #8867293, opened the door to check the clothes, shut it and it would not start. Fuses are not burnt out.What's next?
I too have the Same issue. Did you ever find a resolution to your problem? I bypassed the thermal fuse, jumped the power switch, looked for the non existent belt switch and am still having the problem!
Jan 17, 2011 | Dryers
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
My dryer shuts of during a cycle for a few minutes and then starts again, independent of the heat setting. Kennmore 11062942100
check the venting, if clogged it will trip the high limit ther and cause this issue
Nov 11, 2009 | Dryers
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 05, 2009 | Dryers
Dryer is leaving burn marks on clothes on any temperature.
change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
paul
paul
