Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Frigidaire Gallery Model FWT449GFS1
I washed a small carpet and it fell apart. All the fibres and yarn pieces have clogged up the machine and it will not drain or cycle. I have bailed out the water and drained the hose, but I need to know what part I may be able to replace. I don't know where to start.
  • jhaldeman Aug 07, 2008
    I think that we have already completed most of these steps, but I will try again when I get home.
    Thank you
    Novelist:
  • 116 Answers
There is an obstruction in the drain pump. The only way to clear the obstruction is to remove the lower panel at the front by removing the 2 screws at the lower edge. This will allow the front panel to drop down. You will need to unplug the machine for the next part.
Now this will get a little messy... Be sure to have a lot of towels nearby to sop up the water. On the lower right hand side there is a pump with a black bellows attached which is also attached to the bottom of the tub. This black hose is clamped to the front of the pump if you unclamp the hose the remaining water in the system will spill out. You will have to reach inside the bellows and remove whatever obstruction is inside. some models will have a trap inside which may have to be removed from the top of the hose assembly by unscrewing the clamp on the bottom of the tub.
The hose will have to be reattached in the reverse manner. It can be quite tricky to do so... Once the machine is back together you can run a rinse and spin cycle, it should go into the full spin when all the water drains.
This procedure may have to be repeated a couple of times to completely remove all of the carpet fibres.
Posted on Aug 07, 2008
Frigidaire front loading washer model FWT449GFS1
For a repair manual, contact Frigidaire directly.
Oct 07, 2017 | Washing Machines
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Concrete counterbalance broken (Frigidaire FWT449GFS1)
Check with a company online called sundberg appliance parts, the counterbalance isn't hard to install and will definately be cheaper than new one.
Apr 23, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Errant earring
assuming this has long since been dealt with, but if its not in the rubber gasket at the front of the machine, take off the bottom panel at the front, there is a small pump there that drains the unit. It may be trapped in there. You can use pliers or vice grips to remove the couplers holding the hoses on and a screwdriver to remove it.
Jan 27, 2009 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire Washer Model FWT449GFS1
needlenose pliers grabbing the center shaft (white plastic around a brass center around a screw), turned counterclockwise will free the remainder of the broken knob and allow you to remove it and then screw on the new part.
Mar 23, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Gallery FWT449GFS1 washing machine
http://www.repairclinic.com/referral.asp?R=154&N=1094128
The internal brush can be used to replace brush in similar holder on certain Electrolux, Frigidaire, and Kenmore washers (at least motor # 131276200).
Dec 08, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
414 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
