Question about Acer Aspire 5100 Notebook
Acer Aspire 5507Z Notebook *ACTUAL NOTEBOOK
When I start my computer, the Acer Splash screen shows up, but when it starts to boot, it tells me to check the media cable and that my operating system is not found.
What can I do to fix it? I've tried eRecovery but it also will not work.
  • 25 Answers
Sounds like the hard drive could be bad, or maybe it is trying to boot from the cd drive. The "Check media cable" is the error that bugs me. In your bios, you can usually have the computer boot from a CD Rom drive, or a usb flash drive, etc.. instead of the hard drive where the operating system is. Make that :
1. there is no cd in the cd drive.
2. When the laptop boots, don't touch the keyboard while booting.
Try that and lets see if it will boot into the cd drive.
Posted on Aug 07, 2008
My aspire T671 won't boot passed the acer splash
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
Feb 24, 2012 | Acer Computers & Internet
Acer 7549-1284 shows acer symbol then goes to a black screen, it won't bootup
Well to start u need to go into the bios and shut off the acer splash screen. Then u can see where its hanging up at while its trying to boot.
Aug 16, 2010 | Acer Aspire 7520-5185 Laptop
Possible hard drive failure
Does the splash screen come up? Most of the time if it is your hard drive the ACER splash screen will come up and then a Hard disk 0 error after that. If nothing appears on the screen then you have a bigger issue.
Is there any noise at all (Fan, hard drive spinning)? If so try hooking it to a external monitor to see if there is any movement. You might have a problem with your LCD.
Apr 20, 2010 | Acer Aspire One PC Notebook
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Nov 15, 2009 | Acer Aspire 4315 Notebook
Blue screen on acer extensa 5630 laptop it says its my intel display driver
Try rebooting the computer in safe mode with networking...this is usually done by tapping the F8 key while the manufacturers splash screen shows up for a few seconds. Once the multi-boot screen comes up scroll to safe mode with networking and click ok. Once the computer boots up, it will probably be using a generic video driver to show a picture, go to acer's support site and download a fresh driver, the link is below....good luck. when you click the link, make sure you pick what operating system you are using to get the correct driver. click on drivers > notebook > aspire > 5630 > choose operating system.
http://gd.panam.acer.com/home/
Oct 07, 2009 | Computers & Internet
Acer aspire 5310 the screen just blank and not
Possibly the monitor is defective - usually most laptops have a blue plug at the back for an external monitor, if plugging in a normal monitor brings up a screen, then likely the laptop monitor is defective. If you get a splash screen and bios info on trying to start it,it indicates your windows is defective or has lost it's start-up files - a windows reinstall will fix that.
Aug 29, 2009 | Acer Aspire 5315 Notebook
My Acer Aspire 3000 has a blank screen
I suggest you check the settings of your bios. Normally this happens if your Hard drive is unreadable. Change the settings of the boot function to first boot on Hard disk and try to disable all other bootable hardwares like CD or network card.
Hope this helps.
Apr 22, 2008 | Acer Aspire 3690-2196 Notebook
Acer welcom window frozen in centre of screen.
need to boot up in safe mode or if you have your systems disk load it in and boot up and do a repair or just start it up and close out and reboot with out the disk
Jan 10, 2008 | Acer Aspire 3050-1733 Notebook
Acer Notebook 5610Z - Want XP Drivers
if your currently able to surf the internet with your vista os id suggest downloading the drivers for windows xp from the manufacturer onto a usb storage device like a thumb drive or external hard drive(hdd).
after you have all the drivers you'll need have:
the windows xp disk.
1)before you restart the computer insert the windows xp disk into the cd-rom
2)resart the computer
3)when the computer starts to post press the appropriate hotkey to enter the bios(usually f1,f2 or delete key) it'll tell you on the splash screen.
4)check the boot order in the bios making sure the cdrom is the first boot device. if it is press f10 to save and let the computer boot.
5)on the upper left of the screen you'll see (boot from cd)press any key(hit a key quickly)
windows xp will then start loading on the computer.
6)windows will look for previous installations of operating systems and display them on the screen
7)click on the partition w/the current os (when you click the os will be highlighted)
8)xp will give you the choice to install delete or format the current partition
9)choose to delete the partition
after you delete the partition windows will show a matrix of the hard drive without partitions (RAW SPACE)
10)highlight the raw space
11)choose create
Dec 07, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
525 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
